Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 4 of 12 <123 45 ... 101112>
p38arover
Australia
+44C/111F today and, during an extended run on the motorway, the coolant temp (as per the ScanGauge II) didn't rise above 105 deg C.
It's interesting that the car's temp gauge sits right in the middle from about 80C to 105C Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #423428 18th Jan 2017 8:23am
holidaychicken
I believe the gauge is designed to stay in the middle for a given range, balanced or damped or something i cant remember what he term is but it is so that you know if it starts to move off to the right you are in the poop Neutral
Post #423547 18th Jan 2017 8:02pm
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
Gentlemen,
The BEHR thermostat for 740 D is exactly the same part as in previous post (VEMO branded box)
Bought it for � 72 at the link above / thats 62 pounds in island money Very Happy
And it's including 20% VAT - which makes it 50 pounds when you can supply them with a valid VAT number.
Some patience is needed to give performance feedback - we are making progress on the rebuild....
 Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #423731 19th Jan 2017 1:01pm
holidaychicken
Fook me, you didn't need to go that far just to change the thermostat ! Shocked
Post #423840 19th Jan 2017 8:50pm
MarkNL
Sorry, I lost the manual Cool Mark Offringa
Utrecht Netherlands
Gone:
Post #423942 20th Jan 2017 3:16pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
I ordered the one from ebay... Will install this weekend...
Very curious for the results after reading all your posts 2002 L322 V8
Post #424047 20th Jan 2017 11:43pm
holidaychicken
I am interested too to see what the running temp is with an 88 stat as mine runs at around 93 degrees with the 80.
The bleed procedure is the key as i found out
Post #424145 21st Jan 2017 8:50pm
I tried an 80, 87 and 90something...
Made very little difference to the running temp, just opened earlier or later... Thumbs Up Pete
Post #424177 22nd Jan 2017 12:07am
holidaychicken
That's makes sense, I think the natural running temp is around 90-95 degreees
Post #424193 22nd Jan 2017 10:38am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
You know how that goes. One thing leads to another and you starts saying " while I'm this far I might as well..."
Post #424368 23rd Jan 2017 3:14am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Apologies if this has been discussed elsewhere, but isn't there a direct replacement lower temp thermostat available from BMW? One where there is no need to modify the housing? Accepting it may well be more expensive. Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #424380 23rd Jan 2017 9:41am
holidaychicken
Yes, on page 3 of this thread, MarkNL and myself have ordered them and still have mine as i ordered the 80 deg mod instead
Post #424388 23rd Jan 2017 10:44am
rvbush
Ah yes, so it is Andy, thanks. So, the BMW OEM NUMBER 11512248542 is an 88 deg unit that is a direct replacement part for the standard unit (LR part No. PEL000060, which is a 105 deg unit)? I note you refer to a blanking disk for the heater, is this required for the L322 application?
If possible I'd like to reduce the running temp of my car, but using direct fit replacement parts. Drives:
Post #424409 23rd Jan 2017 1:27pm
holidaychicken
this is what you need
http://www.fullfatrr.com/forum/topic13318.html
The 88 degree blanking plate is part of the vemo stat and is where the heater would be, the plug that normally goes to it would just need weather proofing and tucking away and shouldn't have any effect or dash warnings, it would only show up in diagnostics as a fault.
i have not tried the vemo / stock one as i have the 80 degree mod but i think you would be fine with the 88 and your temp should be around 95 degrees instead of 105 + as per Haylands post it will just open at 88 instead of 80 or 105 for the standard
Post #424470 23rd Jan 2017 9:22pm
alistairh
Delighted to see this bumped tonight as I'm ordering a stat.. so the vemo one is a straight fit no alterations Thumbs Up .. holidaychicken.. off topic matey but how did your investigations go regarding the head gasket issues?
Post #424481 23rd Jan 2017 9:57pm
