![]() | Home > Technical (L322) > Windshield wiper relay |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
It's behind the battery, behind a plastic cover. A bit fiddly to get to, but not too bad.
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
Hi Steve,
OK, well the wiper relay certainly plays a role in sending a trigger that they have reached the parked position, however I cant see that simply pulling the relay and putting it back in again will make any difference. As you needed to remove the battery to get to the relay, it won't be driveable as it is.
Thanks Steve!
Hi Steve,
Number 9 in this diagram. For reference, number 8 is the headlamp washer relay.
Thanks Steve,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
theres a black fuse box in the engine compartment , the relay should be in there.... |
Thanks Stan, thats what i'm trying to find, where the windshield wiper relay is. Mike |
is there not a diagram on the underside of the lid ?... |
does this help,
No diagram but I just pulled the cover off the big plastic box with the 10 torx nuts in front of the battery and found this. One of these has to be the windshield wiper relay wouldn't you think?
Mike,
Thanks Stan! So is the 1 relay for the wipers and intermittent wipers?? |
