![]() | Home > Technical (L322) > Battery Recommendations |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 492 ![]() ![]() ![]() |
The Bosch S5 Battery seems to be pretty high spec. Would the cranking power be greater than the genuine battery though? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8005 ![]() ![]() ![]() |
There have been loads of threads on this one.
handyandy1966 Member Since: 14 Oct 2015 Location: Essex Posts: 20 ![]() ![]() |
I wentt for a varta battery which is OEM spec but less spondeless |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 826 ![]() ![]() |
Jase
timffrr Member Since: 17 Dec 2016 Location: West Sussex Posts: 37 ![]() ![]() |
Euro car parts have got a sale on at the moment running through January so might be worth a look on their website |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Bosch S5 020 110ah or Varta S5 020 (610 200) - just fitted the Varta to my 06 TD6. From previous threads seems the Varta is what LR use as OE but looks identical to the Bosch (which is what it replaced on mine)
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
The Bosch and the Varta are exactly the same, made in the same factory - Bosch does not have its own battery factory 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
Can you categorically affirm they are the same ? Do you work for one of the companies ? Being made in the same factory is not the same thing - there are many things made in the same factory, but with different components or to different specifications. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1371 ![]() ![]() |
got a varta 020 from tayna april 15 its just failed (according to RAC) going to be interesting trying to use the warranty me thinks , charged it to 12.78v left if for an hour it was showing 12.6v used car for 20 mins was down to 12.45v
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 ![]() ![]() ![]() |
i opted the 1 from the stealers. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
This looks good. Good price and lifetime warranty.
@SKOT - thats an 019, only 95Ah not 110Ah, also at £159 it is more expensive.
@mm - Good call. It was what Halfords brought up when I entered my reg number |
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
S5 Bosch tight squeeze but good |
