Home > Technical (L322) > Battery Recommendations
Page 1 of 5 12345>
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Gents,
grateful for advice on a replacement battery for my car. I have a Dec 06 3.6 TDV8 Vogue.
The genuine battery is circa £250 which sounds like a lot but if its the best I'll go for it. Or are the Bosch ones etc a better bet?
Thanks in advance
Jase
Post #421463 6th Jan 2017 4:47pm
Jase71
The Bosch S5 Battery seems to be pretty high spec. Would the cranking power be greater than the genuine battery though?
Post #421465 6th Jan 2017 4:58pm
There have been loads of threads on this one.
Cam-Tech-Craig was always an advocate of the genuine approved battery - for the best reliability.
On my 3.6 I had a Bosch S5 - which I bought from Euro Car Parts - it failed something like 4 years later - they replaced it without question (I still had the receipt) - so I was happy
The Bosch does seem to have a high failure rate
Also - try searching Thumbs Up
Post #421466 6th Jan 2017 4:59pm
handyandy1966
I wentt for a varta battery which is OEM spec but less spondeless
Post #421471 6th Jan 2017 5:13pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Jase
I have an unused Bosch S5 you can have for £50 quid if you fancy a drive over to Brighton.
Bought last year...never used as it is the wrong battery for my RR which requires an AGM.
It has been regularly topped up by a CTEK charger to keep it in good condition.
Post #421475 6th Jan 2017 5:22pm
timffrr
Euro car parts have got a sale on at the moment running through January so might be worth a look on their website
Post #421496 6th Jan 2017 6:42pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Bosch S5 020 110ah or Varta S5 020 (610 200) - just fitted the Varta to my 06 TD6. From previous threads seems the Varta is what LR use as OE but looks identical to the Bosch (which is what it replaced on mine)
Mine was bought from Tayna who I have used a couple of times for batteries, they were about the cheapest and give you next day delivery and the 5 year warranty. Not as convenient as your local ECP but even with the 60% Christmas discount they were still working out at £150~ the Tayna one was about £110~
If you do look at ECP make sure you are looking at the S5 020 - they also list a S5 019 for our cars but it is lower amp hours (90 IIRC)
Cheers,
MM
Post #421498 6th Jan 2017 7:01pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
The Bosch and the Varta are exactly the same, made in the same factory - Bosch does not have its own battery factory 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #421522 6th Jan 2017 10:22pm
Can you categorically affirm they are the same ? Do you work for one of the companies ? Being made in the same factory is not the same thing - there are many things made in the same factory, but with different components or to different specifications.
Post #421548 7th Jan 2017 8:43am
dingg1
got a varta 020 from tayna april 15 its just failed (according to RAC) going to be interesting trying to use the warranty me thinks , charged it to 12.78v left if for an hour it was showing 12.6v used car for 20 mins was down to 12.45v
alternator chucking out 13.9v - will let it die then back to tayna for investigation whats the bets they say 'not covered' under warranty?
anyone else here sent a battery back to them I wonder Question Question
Post #421560 7th Jan 2017 9:58am
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
i opted the 1 from the stealers.
Post #421561 7th Jan 2017 10:08am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
This looks good. Good price and lifetime warranty.
http://www.halfords.com/motoring/bulbs-bla...attery-019
Unless anyone thinks differently? 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #421585 7th Jan 2017 11:46am
mm289
@SKOT - thats an 019, only 95Ah not 110Ah, also at £159 it is more expensive.
Cheers,
MM
Post #421587 7th Jan 2017 11:54am
SKOT
@mm - Good call. It was what Halfords brought up when I entered my reg number Rolling Eyes 2006 4.2 SC
Post #421591 7th Jan 2017 12:15pm
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
S5 Bosch tight squeeze but good
Post #421600 7th Jan 2017 1:28pm
Page 1 of 5 12345>
