Home > Technical (L322) > Stalled after water on road!!!
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
06 td6 stalled after crossing throug water in heavy rain-not deep water.
It started and cruised for 5-6 km and stalled again.
Made home though,what to expect for tomorrow??
Service guy said electric fuel pump may be the problem.
Post #420247 30th Dec 2016 7:34pm
umitbat
Everybody ok_???
Post #420316 31st Dec 2016 6:56am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi, sounds like electrics playing up, as l/p fuel pump is at the lower end of the ff, I would start there.
small cover underneath, by n/s rear wheel arch.
Greg.
Post #420322 31st Dec 2016 8:36am
umitbat
Thanks how will i know it is the cause.
Electrics is worst problem
Post #420325 31st Dec 2016 9:04am
umitbat
Happy new year everyone.
First i couldnot locate the pump:(
Second the lower part of fender is broken is there anything there behind the wheel that could be affected?
Post #420522 1st Jan 2017 8:23am
As previously said, secondary fuel pump is just forward of the left hand rear wheelarch and next to the fuel tank cover, under a plastic cover in the sill channel where the fuel and brake pipes run from back to front.
What is the damage to "fender" - if this is rear bumper it shouldn't have affected fuel delivery?
From RAVE
Post #420550 1st Jan 2017 12:08pm
umitbat
The front wheel arches both have cracks
I think i checked right side not left:)
Post #420591 1st Jan 2017 4:40pm
Do you mean the inner plastic wheelarch protectors?
If so, it will be worth removing these to check for rust / water ingress and to effect some form of repair with glue/tape.
When refitting warm them up with paint gun or fan heater to make them more pliable. .
Post #420592 1st Jan 2017 4:43pm
umitbat
Post #420593 1st Jan 2017 4:43pm
nothing much behind there which could be the problem.
Does sound fuel pump related, like its just getting enough to run for a bit then cutting out which is most likely fuel starvation due to inline pump problems. Have a search there is quite a bit on here about them as it is a common problem. There is nothing that can't be fixed with a hammer😜😜
Post #420594 1st Jan 2017 4:50pm
umitbat
Checked with camera no rust in wheel arches but fuel pump housing has some humid around it but cant check without lift.
Post #420597 1st Jan 2017 5:05pm
its really close to the edge of the car, you should be able to get at it without a ramp. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #420599 1st Jan 2017 5:11pm
umitbat
It ıs nearly in the middle i guess wrong box?
Post #420604 1st Jan 2017 5:38pm
Have a read here.
http://www.fullfatrr.com/forum/topic12487....+fuel+pump There is nothing that can't be fixed with a hammer😜😜
Post #420617 1st Jan 2017 6:29pm
umitbat
So stealer says change the filter and the pump!!!
And anyone knows the ignition thermic part number?
Post #421230 5th Jan 2017 10:55am
