Home > Technical (L322) > Stalled after water on road!!! |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Everybody ok_??? |
31st Dec 2016 6:56am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi, sounds like electrics playing up, as l/p fuel pump is at the lower end of the ff, I would start there.
31st Dec 2016 8:36am |
Thanks how will i know it is the cause.
31st Dec 2016 9:04am |
Happy new year everyone.
1st Jan 2017 8:23am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
As previously said, secondary fuel pump is just forward of the left hand rear wheelarch and next to the fuel tank cover, under a plastic cover in the sill channel where the fuel and brake pipes run from back to front.
1st Jan 2017 12:08pm |
The front wheel arches both have cracks I think i checked right side not left:) |
1st Jan 2017 4:40pm |
Do you mean the inner plastic wheelarch protectors?
1st Jan 2017 4:43pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
nothing much behind there which could be the problem.
1st Jan 2017 4:50pm |
Checked with camera no rust in wheel arches but fuel pump housing has some humid around it but cant check without lift. |
1st Jan 2017 5:05pm |
its really close to the edge of the car, you should be able to get at it without a ramp. There is nothing that can't be fixed with a hammer😜😜
1st Jan 2017 5:11pm |
It ıs nearly in the middle i guess wrong box? |
1st Jan 2017 5:38pm |
Have a read here.
1st Jan 2017 6:29pm |
So stealer says change the filter and the pump!!!
5th Jan 2017 10:55am |
