![]() | Home > Technical (L322) > Stalled after water on road!!! |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Everybody ok_??? |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi, sounds like electrics playing up, as l/p fuel pump is at the lower end of the ff, I would start there.
Thanks how will i know it is the cause.
Happy new year everyone.
As previously said, secondary fuel pump is just forward of the left hand rear wheelarch and next to the fuel tank cover, under a plastic cover in the sill channel where the fuel and brake pipes run from back to front.
The front wheel arches both have cracks I think i checked right side not left:) |
Do you mean the inner plastic wheelarch protectors?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
nothing much behind there which could be the problem.
Checked with camera no rust in wheel arches but fuel pump housing has some humid around it but cant check without lift. |
its really close to the edge of the car, you should be able to get at it without a ramp. |
It ıs nearly in the middle i guess wrong box? |
Have a read here.
So stealer says change the filter and the pump!!!
