Home > Technical (L322) > Removing ball joint - at wits end
Page 3 of 7 <1234567>
holidaychicken
sounds like you are having a time, i wonder if the car has been waded..
Do you have decent sockets and breakers bars, i have never managed to round a bolt but i do make sure i hammer the socket home fully as all the nuts and bolts are rusted and i have a couple of big breaker bars that i can usually get onto a nut or bolt with which makes a massive difference when trying to undo things as you are not struggling and pulling the socket off in different directions. i also use normal hex sockets where i can and i have halfords shock and unlock or WD specialist fast release penetrant.
were you using the air gun on a big compressor as i bought a windy gun for my compressor which is not huge and the gun is useless?
i have linked a couple of spanners together as well to get me some extra leverage.
I have a good 1/2" drive socket set and a couple of breakers bars
This is one of my favourite bars in action.
this is my biggest breaker bar that weighs in at around 5 ft long, that is not the bonnet prop, that is to undo the crank pulley !
Post #420091 30th Dec 2016 12:07am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Blimey!
I bought myself a 2ft breaker bar the other day, nice bit of kit!
I don't have a hex socket at the moment, something I need to get hold of if I try any more!
I'm really disappointed with myself, I've yet to have given up on a job on my own vehicle! Even managed to do a radiator and turbo in the past!
Something I find hard with the ff, struggling to jack it up high enough to get the wheel off for starters, then I have no room to negotiate the breaker bar... if only I had a ramp / pit!
I'll think about it in the morning, if I can get the caliper off, then the disc I should be able to get a bit further!!
Post #420094 30th Dec 2016 12:15am
Stacker
And talking of being waded, I present you with a hub nut Sad
Post #420095 30th Dec 2016 12:22am
holidaychicken
I edited the post and added a couple of other bits, linking spanners can help.
i have a trolley jack for 4x4's which helps, again halfrauds, it has an extension piece on it so you can get right up to the jacking point before it even starts jacking and then i have some tall axle stands.
another thing i have done is to drive up onto some railway sleepers which is what i had to do to torque up the front suspension as this needs to be done with the weight on the wheels so the bushes don't tear.
Put it in low ratio and it crawls up nicely, i have had all 4 up before. the sleepers i bought cheap off ebay and chopped them up, i dont mind getting under it so much when it is on them, 2 1/2 tonnes on a axle stands is a little unnerving..
You can sometimes access a bolt to crack it and then undo it completely with a a standard socket
let me know if you have had enough of the fots !
Post #420097 30th Dec 2016 12:27am
holidaychicken
You could always make yourself some scaffold board ramps, these were for my transmission project.
Post #420099 30th Dec 2016 12:34am
holidaychicken
Holy crap, that is bad, that has been used to wade in salt water by the look of things, heres mine.
Post #420102 30th Dec 2016 12:55am
Stacker, think I'd be looking at a replacement hub and drive shaft, or at least outer CV joint, doesn't look like you have much of the nut left at all....
Plenty being broken on eBay...
No wonder you are having such problems, did the FF come from the seaside...??? Pete
Post #420105 30th Dec 2016 2:02am
Stacker
Thanks for the pictures, I'll see if I can make something up and have another go on Sunday. I might look into getting a dremel as if I can get that in there I wouldn't need to take the brakes off at all, cut the head off the bolt then knock the Censored crap out of the ball joint!
I also had another thought I could have probably got the arm off the ball joint with the air gun, if I could use the nut to spin the ball joint... or wouldn't that work?
Hay lands - that thought has crossed my mind, but I might just leave it for now! The others are like it too I think it must have been parked in the sea for a little while!!
Post #420133 30th Dec 2016 11:42am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I really really like this idea!! I presume it's definitely safe to carry the 2.5 ton weight? lol
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #420236 30th Dec 2016 7:57pm
Rangeyman
Like every job on the Ffat,it is hard work but one thing I have learned with age is spraying up before tackling a job ,either the day before or even better a few times even a week or two before,you will be amazed with the difference.
Post #420263 30th Dec 2016 9:44pm
Stacker
One step closer to heaven baby!! It's out I managed to smash a socket over it!!!
Post #420266 30th Dec 2016 9:54pm
Bet that was a " Censored yeah!!!! Baby" moment
Did you manage to get it out of the hub? There is nothing that can't be fixed with a hammer😜😜
Post #420277 30th Dec 2016 10:49pm
holidaychicken
Good effort, that's the spirit, these fecking cars are just a massive mind Censored puzzle , I am waiting for my leak down tester to turn up to determine if I need a new engine !
Keep the faith brother 😁
Post #420279 30th Dec 2016 11:23pm
Stacker
I was shocked but happy!!
Not got it out of the hub yet, still trying! It's solid Sad
Post #420280 30th Dec 2016 11:26pm
Stacker
This is how far I've got today, had to stop now for work
Not sure where to go from here it doesn't seem to be moving! Air chisel?
Post #420294 31st Dec 2016 12:37am
