Home > Technical (L322) > Removing ball joint - at wits end
Page 5 of 7 <1234567>
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Happy new year to you too!
Achieved this today
Took two of us 15 minutes, one with the air chisel under the 'ear' and me hitting from above with a metal bar at the same time, then it popped out!
No more knocking Very Happy thanks for all the support guys, have a great year!!!
Post #420596 1st Jan 2017 6:01pm
Thumbs Up Thumbs Up Thumbs Up Very Happy .
Post #420601 1st Jan 2017 6:33pm
holidaychicken
Good effort, i learned very early on that the pleasure from owning these vehicles is not the driving, it is overcoming the many challenges they present you!
have you done both sides?
I find that by the time you have done the job you could do it again really quickly but hopefully you don't need to do it again.
Post #420606 1st Jan 2017 6:48pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Well done!!!. Now gives me hope when I come to replace mine. Happy New Year to all. Thumbs Up Thumbs Up
Post #420608 1st Jan 2017 6:52pm
TJH1985
Had this very battle today, just came on to see if there was a better way!
It was about 30 minutes for me, with these weapons of choice:
With this being the result:
The bush leads you into a false sense of security as it just slides out Censored
Post #523699 3rd Aug 2019 9:59pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Eugh, did this today on the passenger side
Got the arm off easy.
Onto the bush, one of the Torx bolts came out easy - the one to the front of the car which is harder to access rounded out. tried to drill it, then drilled a hole in the side of it and used a punch to knock it around which thankfully worked.
On to getting the bush out - heat didn't help, WD40 didn't help.
What helped was holidaychicken's tip the most was trolley jack under the front ball joint to make sure every hit from above counts, and just keep hitting it like Asda- every little helps!
Post #545253 26th Feb 2020 8:57pm
GGDR
A job for Plus Gas vs WD40 ?
I bought some (but not used it yet) as they say it's world's apart from WD40
. Cheers, Greg
Post #545268 26th Feb 2020 10:07pm
Knock/drill/smash the gubbins out of the housing, helps if you remove the back of the ball joint with a punch and some Levering/wiggling......
Then the main bits of the joint can be taken out. Leaving just the outer case in place.
Then put a hack saw through the joint and saw a groove in the side of the joint through to the hub. This will then release it a mm.
It can then be knocked out a lot lot. easier There is nothing that can't be fixed with a hammer😜😜
Post #545273 26th Feb 2020 10:31pm
Gsxr1250dave
This job is much easier if you just remove the hub a couple of well placed hammer wacks and its out
Post #545281 26th Feb 2020 11:44pm
steptoe
Freeway - very specialised but the best at it's job.
image uploader
Post #545347 27th Feb 2020 3:21pm
steptoe
Post #545348 27th Feb 2020 3:21pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
it could be! i decided on that strategy but couldnt get the fkin strut bolts out even with a 4 ft bar. since learnt that a tig welder makes an ideal way to heat bolts to crack rust siezed bits
Post #545410 28th Feb 2020 2:03am
ohuntsman
So the driver's side was much harder!!!!
I followed northernmonkeyjone's tip of ripping the cap off, pulled out the ball joint then hacksawed through the casing, I then put the ball joint back in sans plastic casing and hit the ball with my chisel and it fell straight out
To make matter worse the hard to reach locating bolt is seized and had to be cut off. It wouldn't drill out so off to weld a nut on to the stud today and hope for the best!!!
Post #545416 28th Feb 2020 10:27am
Walkeraj101
Hey, I've been trying for weeks to get the ball joints out of my wheel knuckle. Started with splitters and pullers which all bent and snapped. Moved to hammers, sledge hammers and chisles. Then to air hamner and then finally to jack hamner! Oblitorated the top of the ball joint and still hasnt budged a millimeter.
Eventually I conceded defeat and purchased 2 new wheel knuckles. New Ball joint fits in nicely.
So I assembled the new knuckles with new bearings, dust shield and hubs.
Went to remove the old knuckles thinking it would be a breeze now. How wrong was I. Now I cant get the CV splines out of the hubs! As with the ball joints the splines are fused in with rust. I've been hiting with sledge hammer for over 8 hrs and no movement. Just mushroomed the CV head.
So now purchased 2 new CV heads and will try to seperate the shaft from the fused head in the hub. I'm praying this will pop out with a few knocks from the hammer as they are just pop in circlips. Though not holding too much faith in this being the case based on all the other issues.
So, now in for £1000 to just change a £20 ball joint. Big Cry
I almost lost the will to live with this but decided to percivere.
In my opinion what a total cock up design by RR for ball joints and CV's.
Will feedback how it goes. I hope I dont need to but complete drive shafts Big Cry
Post #554370 18th May 2020 9:06pm
As I said.......
Knock off the back of the ball joint with a punch, just basically smash it off.....
Then you can furtle around drill and smash the actual ball out of the casing.
Once you have the centre out put a hacksaw through the hole and cut a slot in the side of the casing.
Will then knock out. Did both of mine on my 12
Plate that way. There is nothing that can't be fixed with a hammer😜😜
Post #554392 18th May 2020 10:19pm
