![]() | Home > Technical (L322) > Removing ball joint - at wits end |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
some photos for inspiration
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Still can't get it off |
Look like the trick is a big fat cold chisel on the ears of the ball joint, or maybe even your fork splitter |
Did you try the sharpened cold chisel, that is what worked for a couple of us, but always easier if you can take it somewhere with better facilities? |
I haven't yet as I need to at least get the other bolt out first, it I can get that out I don't need to get the arm off the ball joint as they're both getting replaced obviously!
Did you try tapping in the next size up torx bit into the bolt ? |
I did try, it's so seized up it just rounds instantly.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Yes torx heads on rusty bolts are a stupid idea!!
That's what I was thinking!
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
that's why I leave it all to the dealers to sort good luck ! |
Got to find a garage that will attempt it now |
had mine done by beadles |
i think you are still in with a chance if you can get a grinder to the heads of the bolts and grind them back until you reach the lugs, then as you say, remove the ball joint using a a chisel and hammering from the top while supporting the hub which should leave a small amount of thread that you can heat the top of and from underneath and a splash of shock and unlock for good measure and then try mole grips on what is left protruding of the thread as i doubt you will get a stud extractor on it or screw a nut on if there if is any thread that is left and weld it to it. In theory once the head of the bolt is gone it is only the rust that is holding it in. This may depend on getting that bottom ball joint split for access or getting it to a garage while you can still drive it. Pic below showing the splitter i used
It's literally either that or garage, but as I said can't even get the brake caliper bracket off!
