Home > Technical (L322) > Removing ball joint - at wits end |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
some photos for inspiration
29th Dec 2016 11:33am |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Still can't get it off
29th Dec 2016 12:23pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Look like the trick is a big fat cold chisel on the ears of the ball joint, or maybe even your fork splitter .
29th Dec 2016 12:51pm |
Did you try the sharpened cold chisel, that is what worked for a couple of us, but always easier if you can take it somewhere with better facilities? |
29th Dec 2016 12:56pm |
I haven't yet as I need to at least get the other bolt out first, it I can get that out I don't need to get the arm off the ball joint as they're both getting replaced obviously!
29th Dec 2016 2:00pm |
Did you try tapping in the next size up torx bit into the bolt ? |
29th Dec 2016 2:28pm |
I did try, it's so seized up it just rounds instantly.
29th Dec 2016 4:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
Yes torx heads on rusty bolts are a stupid idea!!
29th Dec 2016 4:51pm |
That's what I was thinking!
29th Dec 2016 5:09pm |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
that's why I leave it all to the dealers to sort good luck ! |
29th Dec 2016 5:32pm |
Got to find a garage that will attempt it now guess I'll be cancelling my trip to Germany on the 8th! |
29th Dec 2016 5:39pm |
had mine done by beadles |
29th Dec 2016 5:42pm |
i think you are still in with a chance if you can get a grinder to the heads of the bolts and grind them back until you reach the lugs, then as you say, remove the ball joint using a a chisel and hammering from the top while supporting the hub which should leave a small amount of thread that you can heat the top of and from underneath and a splash of shock and unlock for good measure and then try mole grips on what is left protruding of the thread as i doubt you will get a stud extractor on it or screw a nut on if there if is any thread that is left and weld it to it. In theory once the head of the bolt is gone it is only the rust that is holding it in. This may depend on getting that bottom ball joint split for access or getting it to a garage while you can still drive it. Pic below showing the splitter i used
29th Dec 2016 7:54pm |
It's literally either that or garage, but as I said can't even get the brake caliper bracket off!
29th Dec 2016 8:25pm |
