Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005
Page 3 of 12 <123 4 ... 101112>
Re: Lower thermostat modification V8 4.4 M62 2002-2005
The reason is stated in the first post..... Thumbs Up
Haylands wrote:
one weak spot is the plug to the electrical thermostat, the seal fails and coolant is forced into the electrical plug and, believe it or not, follows the easiest path which is up inside the wires and into the engine ECU in the electrical box in the engine bay, this corrodes the ECU and causes all sorts of problems. This can still leak with the stat removed so don't plug it back in, just tuck it behind facing downwards so any moisture can drain. This does log a fault with the engine ECU but it is a soft fault and DOES NOT illuminate the check engine light (MIL) It is not a sensor, just a switch so it doesn't effect anything else.
 Pete
Post #409472 16th Oct 2016 9:26am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Thumbs Up Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #409474 16th Oct 2016 9:36am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
[quote="Haylands"]Been loads talked about this recently but no "one place" to find all the info...
From RAVE
[i][color=red]The die-cast coolant pump, driven by an ancillary drive belt, is fitted to the timing case cover. It contains the dual coolant temperature sensor and the electrically heated 'map controlled' thermostat controlled by the engine management system.
Hey Pete, is the temperature sensor in the stat wiring that you remove? If so do you still get a coolant temp reading?
Post #416429 3rd Dec 2016 11:35am
UK Marine
Hi,
The temp sensor is located elsewhere so leaving out the thermostat plug will not effect the temp reading.
Regards ______________________________
Simon
Post #416430 3rd Dec 2016 11:39am
That bit in Rave is a bit ambiguous, there is one temp sensor measuring the water at it's hottest part of the system, where it leaves the engine, and as Simon says it's not combined with the electric thermostat. There is another temp sender in the bottom hose outlet in the rad, which is the coldest part of the system. The internal temp gauge uses the top one, the bottom one can be read with diagnostic tools... Thumbs Up Pete
Post #416435 3rd Dec 2016 12:21pm
ohuntsman
Thank you Pete, I've been watching the diagnostics in my last journey. The FFRR started getting warm so pulled over and put the heating in high with the ignition on (thanks to the new battery!) plugged in the diagnostics and the coolant temp was at 115 and the radiator temp at 5 deg.
The diagnostics threw out a stat sensor fault as well.
Limped home with the heating up and windows wide open and the rad temp didn't move north of 7 deg. While the coolant hovered from 95-100.
Having gone through your write up I'm thinking there may be a leak through the stat sensor - if there is and I rip out the internals and do the mod is there a way to seal the sensor housing?
Post #416439 3rd Dec 2016 12:44pm
ohuntsman
& Simon of course Embarassed
Post #416440 3rd Dec 2016 12:45pm
If the rad never got higher than 7 deg then you have no water flow around the system, the other temp got cooler because the water would be stationary and as such the heat will have dissipated into the surrounding metal work. The temps inside the engine will have been very high.
It's either a stuck thermostat, broken water pump or blocked system (probably the rad)
Don't drive it till it's fixed or you could do the head gaskets...
Doesn't sound like a leak through the stat to me but if it is there are lots of substances that would seal it, but for how long is anyone's guess.. Pete
Post #416459 3rd Dec 2016 4:04pm
p38arover
Australia
40 deg C/104 deg F today and the water temp got up to 104 deg C/219 deg F a couple of times in traffic. Once moving, the temp dropped to 102 deg C/216 deg F.
I have a ScanGauge II http://scangauge.com.au/scangauge2/ connected to the OBD port Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #417691 13th Dec 2016 8:08am
holidaychicken
Did my 80 degree mod at the weekend along with the top hose, might just be me but it seams so much happier and doesn't smell like Chernobyl after I've been on a run now either
Post #417798 13th Dec 2016 9:25pm
UK Marine
I did the mod and I couldn't believe the difference either, it was like all of the strain was being released from the engine and it just sounded and felt more relaxed, it was odd...
Excellent mod though.... ______________________________
Simon
Post #417857 14th Dec 2016 11:44am
holidaychicken
Really easy to do too, i didn't need to mod my housing for the bleed valve and didn't remove the fan or cowling either and as I used a 1/4 drive ratchet and extension it was really easy to undo and replace the 4 bolts and didn't need the cap head bolt.
Regarding the modification to the old housing , i used a dremel with the little reinforced cut off discs and then a coarse sanding drum again in the dremel and job was done.
The old stat spring is under quite a bit of compression so does ping a bit when you cut through the supports.
Definitely more relaxed even on idle now
Post #417920 14th Dec 2016 7:00pm
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
http://www.onderdelenshop24.com/7016322-behr-thermot-tronik
Anybody out there who ordered this part yet ? Its the BEHR thermostat model TI 3288 for the 740 diesel.
BMW part number is OEM NUMBER 11512248542 THERMOSTAT / opening at 88 degrees...
Has the exact same dimensions and design as the BEHR thermistat TM 12 105 --- this is OEM number 1153 1 436 386 / for BMW / opening at 105 degrees ... which is the same as "our" original OE PEL000060 / for LAND ROVER
Hope to hear more.... Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #420766 2nd Jan 2017 3:53pm
holidaychicken
i ordered one of the vemo ones but didn't use it as i fitted the 80 degree mod, it is still in my garage in it's box.
When you look at the actual casting it says Behr on it.
The blamking disc that says 88 on it is where the heater would normally fit.
It cost me just under £90 to get it to the uk via amazon so the 80 degree mod is cheaper
https://www.amazon.co.uk/dp/B00HAH8AU8/ref..._ttl_sol_0
Post #420774 2nd Jan 2017 4:48pm
Lots of ways to get the temp lower, doesn't matter which one you use, this was the cheapest I could find... Thumbs Up Pete
Post #420798 2nd Jan 2017 6:33pm
