![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8444 ![]() ![]() ![]() |
Not got it swapped yet... Pete
rnitto Member Since: 08 Dec 2016 Location: NJ Posts: 12 ![]() ![]() |
I found a unit with flush/straight sides. Im talking to Eonon to confirm that this will work with the L322. I like the green illumination, all it will need is the Rover splash screen logo. My goal would also be to hook up an economical aftermarket amp setup to get the best possible sound.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That's an Erisin unit and the sides are curved |
Sorry I had the wrong link, this is the one...
Well I can't see why it wont fit, it's definitely got all the right kit and as you say is a better fit that the X5 unit. I'm not sure that I'd bother with an amplifier.... maybe buy a couple of long Phono extension leads and run them to the back from the Aux out and Sub out, just incase you don't like the sound... at least that way you don't have to have the whole car apart again to add an amp |
I've been saying this since the beginning but nobody believes it, mine runs without a subwoofer, and without the center speaker at the front as I have the CB running through, I just have the door speakers wired in to the head unit, no extra amp or cross overs etc and it sounds fine.... It is totally acceptable for 90% of people, if you are one of the fortunate 10% who can notice a drop in quality then maybe an amp and other bits may help but what's the point of spending more money until you try it, it costs no more and isn't even much work to try it as it and see, or hear if you think it's OK... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Pete,
I would imagine so, you have to get into the factory settings (126 is a popular number) to change it though...
Ok thank you! I will post feedback if I get this unit. |
You should use a microphone with the correct impedance for the unit, whether they are the same or not I don't know and I doubt you will find that sort of info out....
Ottar Member Since: 07 Jun 2016 Location: Bekkestua Posts: 8 ![]() ![]() ![]() |
Thanks for the advice.
Cheebs Member Since: 04 Jul 2017 Location: Georgia Posts: 18 ![]() ![]() ![]() |
I Understand that these units don't work with the MOST system. What i need to know if I can use the harness and head unit to connect the power and Steering wheel controls ONLY? I have a 06 RR HSE. I will be replacing the speakers and amps and getting rid of the MOST pieces. I don't understand the electrical guide as i can't tell what year and system the diagrams are for. Am i assuming right that the 06 RR has the 40 pin connector? I am trying to do as little cutting of wires as possible. |
You will lose all the features that are displayed on the headunit currently fitted, it will not be plug and play but it is easy enough to chop the leads off the plug and sort them out to a new amp and speakers. The new unit does have an internal amp which is OK for general listening... Pete
Sorting out the amps and speakers is easy. I want to make sure that the power and steering wheel controls will work everything else i don't really need. My 06 RR seems to be a one off year and the info on it is little to none. How do i know What year and unit they are talking about in the rave? |
