Home > Maintenance & Mods (L322) > Aftermarket DRL light problem
headless21
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi, I have just fitted some Hella Daytime Running Lights complete with relay/control box to my 2011 range rover vogue se TDV8 today but I have a strange problem. I connected power and earth from DRL control box direct to battery + and - as the instructions said. When I start the enine the lights come on as they are supposed to do but when the engine e is off the DRL come on everytime I open a door or lock/unlock vehicle. I would be very grateful if anybody can shed some light on why the lights come on when I open a door or lock/unlock vehicle and how to cure this problem as I am baffled.
The lights are supposed to sense the increase in voltage when vehicle engine starts and turn on DRL.
Any help would be much appreciated.
Martin Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
2003 Range Rover Vogue SE
1997 Range Rover DSE
1990 Range Rover Vogue SE
1985 Range Rover 2 Door
1979 Land Rover Series 3
Post #412945 10th Nov 2016 3:54pm
miggit
I suspect that it's the wire you have tapped in to, to feed the DRL's... I used a wire in the main ECU box to feed mine Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412961 10th Nov 2016 5:26pm
this type of drl switch is voltage sensitive so when you lock/unlock it trips the switch....
i have my 'norma'l drl switch wired to an ignition feed and also to the headlight feed so when you put the headlights on the drls go off.. ... - .- -.
Post #412964 10th Nov 2016 5:35pm
miggit
DIY info Thumbs Up
http://www.fullfatrr.com/forum/topic30311.html?highlight=drl
Well down the search list... but I found the little devil Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #412966 10th Nov 2016 5:37pm
that link refers to the 2003, the OP has a 2011 and the wiring is different Paul but it gives you the idea how to do it. Thumbs Up ... - .- -.
Post #412967 10th Nov 2016 5:41pm
miggit
Rolling Eyes I know that they is different Whistle just couldn't find anyone who'd added DRL's on a later ffrr and posted about it Whistle
As far as I know the later ffrr's still have a black box under the lid.. equipped with a multi meter it shouldn't be too hard to find a feed... also the feed that I used stays live for about 15 seconds after the key has been removed.. so wait a wee while before trying another wire Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412970 10th Nov 2016 5:48pm
i stuck some halos on my westie and posted about it ...didnt say whta wires to use though and you're correct the lights do stay on after lock.. Thumbs Up
http://www.fullfatrr.com/forum/topic38570.html?highlight=drl
the ones i put on my SC and then later onto my westie,
http://www.fullfatrr.com/forum/topic33047.html?highlight=drl ... - .- -.
Post #412973 10th Nov 2016 5:55pm
As you have connected to the battery +ve and -ve terminals I be inclined to go back to your supplier and ask them.
Post #412977 10th Nov 2016 6:10pm
miggit
Wonder if it's looking for the voltage to go above 12 volts to turn on the lights.. as the ffrr sits at a slightly higher voltage at rest, it could go a long way to explaining your blinking lights Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #412979 10th Nov 2016 6:16pm
headless21
Hi all, Thanks for All your kind comments, it's sounds like I will have to find an ignition live instead of the battery terminals. Reading instructions the relay box looks for voltage to rise above 12v to trigger relay to turn lights on.
Thanks again for your help.
Regards Martin Current Range Rover Vogue SE 2011 4.4 TDV8
Previous
Post #412985 10th Nov 2016 6:46pm
miggit
As suspected, the ffrr's sit at 12.5volts minimum, with the car's ECU's cutting in and out there are voltage fluctuations for about 30 minutes after it's been locked Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412986 10th Nov 2016 6:50pm
