Home > Maintenance & Mods (L322) > Aftermarket DRL light problem |
headless21 Member Since: 28 Jun 2016 Location: Yorkshire Posts: 23 |
Hi, I have just fitted some Hella Daytime Running Lights complete with relay/control box to my 2011 range rover vogue se TDV8 today but I have a strange problem. I connected power and earth from DRL control box direct to battery + and - as the instructions said. When I start the enine the lights come on as they are supposed to do but when the engine e is off the DRL come on everytime I open a door or lock/unlock vehicle. I would be very grateful if anybody can shed some light on why the lights come on when I open a door or lock/unlock vehicle and how to cure this problem as I am baffled.
10th Nov 2016 3:54pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I suspect that it's the wire you have tapped in to, to feed the DRL's... I used a wire in the main ECU box to feed mine Yesterday I couldn't spell Engineer... Today I are one!
10th Nov 2016 5:26pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
this type of drl switch is voltage sensitive so when you lock/unlock it trips the switch....
10th Nov 2016 5:35pm |
DIY info
10th Nov 2016 5:37pm |
that link refers to the 2003, the OP has a 2011 and the wiring is different Paul but it gives you the idea how to do it. ... - .- -.
10th Nov 2016 5:41pm |
I know that they is different just couldn't find anyone who'd added DRL's on a later ffrr and posted about it
10th Nov 2016 5:48pm |
i stuck some halos on my westie and posted about it ...didnt say whta wires to use though and you're correct the lights do stay on after lock..
10th Nov 2016 5:55pm |
Wonder if it's looking for the voltage to go above 12 volts to turn on the lights.. as the ffrr sits at a slightly higher voltage at rest, it could go a long way to explaining your blinking lights Yesterday I couldn't spell Engineer... Today I are one!
10th Nov 2016 6:16pm |
Hi all, Thanks for All your kind comments, it's sounds like I will have to find an ignition live instead of the battery terminals. Reading instructions the relay box looks for voltage to rise above 12v to trigger relay to turn lights on.
10th Nov 2016 6:46pm |
As suspected, the ffrr's sit at 12.5volts minimum, with the car's ECU's cutting in and out there are voltage fluctuations for about 30 minutes after it's been locked Yesterday I couldn't spell Engineer... Today I are one!
10th Nov 2016 6:50pm |
