Home > Technical (L322) > stall speed: what should be OK? |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
What's this in aid of? I would have thought it puts unnecessary strain on already weak parts e.g. Gearbox and torque converter? |
27th Oct 2016 8:48am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^time bomb and ticking come to mind
27th Oct 2016 9:29am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
Checking the stall speed is a recognised way of detecting faults with a TC, in a well running box that is up to temp it does not harm the box to test it once or twice.
27th Oct 2016 10:13am |
Not sure where my negativity regarding my TD6 comes from, it never breaks
27th Oct 2016 10:28am |
Pete I looked in to a super duper all singing and dancing H/D torque converter... and by the time I had paid for it and the shipping I could have had the gearbox rebuilt they ain't cheap... went for a totally new, never rebuilt one instead Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2016 10:52am |
Pete
27th Oct 2016 4:12pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
thnx for your replies
27th Oct 2016 6:43pm |
Yup but only going up hill backwards .... the transmission oil pick up is at the back of the gearbox.. and when you put your foot down too hard going up hill backwards, all the oil flies to the front of the box away from the pick up and causes starvation ... end result hiccup from the box ..... it just goes to show how bad the design of the gearbox is to start with, let alone how unsuited it is for a 4x4 Yesterday I couldn't spell Engineer... Today I are one!
27th Oct 2016 10:10pm |
I agree with the design and just thought this was the cause of the problem, but then I tried it on a flat surface and the problem is exact the same When at idle it drives easily backwards, but giving throttle will make it hick-up and you feel it doesn't have as much torque as it has in forward |
28th Oct 2016 6:37am |
Low oil?
28th Oct 2016 9:05am |
indeed the design is not one of the best i guess... and in reverse i can imagine there's not enough oil flow, but the design does not explain the same symptoms when on flat surface....
28th Oct 2016 9:33am |
RRPhil knows enough about the GM5L40E gearbox to specialise in the ZF box instead There's a lesson there if someone who knows about auto's don't want to know
28th Oct 2016 10:05am |
My gearbox re-builder wanted to exclude a valve block failure so today he installed a new one. It didn't cure the problem
18th Nov 2016 8:31pm |
I wonder if it could be pressure related... too much rather than not enough... like the pressure relief valve keeps on blowing... bit like a pressure washer with a semi-blocked nozzle Yesterday I couldn't spell Engineer... Today I are one!
18th Nov 2016 10:36pm |
