Home > Technical (L322) > stall speed: what should be OK? |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Thanks Miggit, keps me puzzling and found this on the web: http://www.sonnax.com/articles/130-5l40e-5...rse-or-tcc
19th Nov 2016 8:09am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
It sounds like there is a Hydraulic related problem in that box... some how it's cutting the oil flow to the reverse gear and then resetting it's self... so you end up with an on / off cycle.... Does it do it all the time or is it only under hard acceleration? which would increase the pressures in the system and possibly cause the over pressurisation... it could be a leek under pressure, but I still get the feeling that its' a pressure relief valve some where in the box that's at fault.
19th Nov 2016 12:17pm |
