Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
mines in for this tomorrow and its under warranty as i have a LR approved warranty..
23rd Oct 2016 1:56pm |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 |
Is there any way you can tell if this mod has been done? Mine is not smoking or acting up in any way at all, but I would like to know whether or not I am likely to have problems. I had it done on my Disco which was smoking badly on acceleration. |
23rd Oct 2016 3:09pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
Stan,
23rd Oct 2016 3:20pm |
thanks Michael, feeling better after my second op....
23rd Oct 2016 3:32pm |
I have got a paper copy of the relevant Technical Bulletin ( LTB005513v4 ) which is very comprehensive with lots of pictures and 17 pages of detailed instructions, but , sorry, I have not got a scanner so aren't able to share it . |
23rd Oct 2016 3:48pm |
Thanks, I am in the dealers this week as I have the P040D code investigated - but no adverse effects resulting from that code. I will ask them to have a look. |
23rd Oct 2016 4:21pm |
im sure it's on here somewhere as a pdf, i'll see if i can find it later.... ... - .- -.
23rd Oct 2016 4:22pm |
i've uploaded it to the wiki,
23rd Oct 2016 5:16pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Had a couple of instances of smoke on mine.
23rd Oct 2016 6:05pm |
Thanks Stan that's very useful. Phil |
23rd Oct 2016 9:37pm |
you're welcome phil...
24th Oct 2016 12:15pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
24th Oct 2016 12:58pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1381 |
I was told that one of my turbos has an oil weep, which the mod would address - that is the only way I know about it as no smoke. No warranty and apparently LR do not offer any assistance with cost, it is about 8 hours work, mine is to be checked in the spring for deterioration. It would be nice if LR would contribute, as it seems a design fault and not a cheap fix. Only Range Rovers since 1988 |
24th Oct 2016 1:45pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 |
I knew about this problem when I was looking for a 4.4 TDV8 earlier this year so when I found the right car I managed to provoke the smoke problems on the test drive. The car was in a main dealer (non LR) and they agreed to get the mod done as part of the deal, they had no luck getting any help from the local LR dealer and had the job done at Team Valley Land Rover and I have a copy of the invoice for £948.44 inc VAT.
24th Oct 2016 9:46pm |
