Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
Anyone know just how large a bulb you can get away with,i know it is listed as 6w but others have put much larger ones in ok but if it connected to the trailer reversing cables surely it has to cope with what a trailer bulbs use.Just thinking of some extra reversing light possibly mounted in an inconspicuous place as just below the bumper . |
15th Dec 2015 8:26pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
All the trailer lights are fed through a relay so there is no drain on the wiring of the car........ but that's not to stop you using a relay to power your extra lights Yesterday I couldn't spell Engineer... Today I are one!
16th Dec 2015 12:31am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
As well as my brighter original reverse lights I also have a pair of supplementary led spot lamps mounted below the rear trim below the rear bumper. I have these wired through a pair of relays such that when I select reverse in daylight only the original reverse lights light up, when I have sidelights on the supplementary spot lamps also light in addition to the original.
16th Dec 2015 7:41am |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 |
Just upgraded my reverse lamps with the G4 ones, picture below is a before & after, bulb on the right is the Hungarian 21w lens melter, (I added an extra rubber ring to prevent melting) on left is the G4 bulb, ordered bit from bay of E, literally is a ten minute job (as long as you can solder) snipped of the old bulb carrier and soldered on the new socket, bit of heat shrink over joint, all done, really good instructions earlier on in this thread, look better in real life than the pic, really bright & white, worthwhile mod.
22nd Dec 2015 3:53pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
Well I liked the two sets of pcb's upgrade so I set about it,
24th Dec 2015 2:10pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Just a quick update, decided to fit three of the G4 LED lights to each side. EXCELLENT results Pics below...
20th Jan 2016 11:30pm |
dognero Member Since: 27 Jul 2016 Location: durham Posts: 41 |
Will these be ok?
21st Oct 2016 9:53am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
anything is better than stock...pot luck which is brighter so you need to try them and see .. ... - .- -.
21st Oct 2016 10:08am |
The biggest problem with those is there will only be enough room to fit 1 bulb per light..... and there is a restriction in the lens that will make it impossible to fit a large bulb, it wont go through the hole So your then limited to narrow bulbs that will be considerably less power than what is fitted at the moment
21st Oct 2016 10:14am |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
I added some of these to mine
21st Oct 2016 1:11pm |
It can never be too bright when going backwards in the dark Yesterday I couldn't spell Engineer... Today I are one!
21st Oct 2016 3:02pm |
Ordered 4 of these and see what they are like.
22nd Oct 2016 9:48am |
thats the ones i have in mine... ... - .- -.
22nd Oct 2016 9:53am |
That is spookie reckon I've used the same Yesterday I couldn't spell Engineer... Today I are one!
22nd Oct 2016 10:43pm |
