Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs?
Page 16 of 22 <123 ... 151617 ... 202122>
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
got my G4 5w bulbs...now for the g4 socket to get here so I can epoxy them into the reverse light Very Happy 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #362321 15th Dec 2015 12:30pm
Rangeyman
Anyone know just how large a bulb you can get away with,i know it is listed as 6w but others have put much larger ones in ok but if it connected to the trailer reversing cables surely it has to cope with what a trailer bulbs use.Just thinking of some extra reversing light possibly mounted in an inconspicuous place as just below the bumper .
Post #362382 15th Dec 2015 8:26pm
miggit
All the trailer lights are fed through a relay so there is no drain on the wiring of the car........ but that's not to stop you using a relay to power your extra lights Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #362401 16th Dec 2015 12:31am
As well as my brighter original reverse lights I also have a pair of supplementary led spot lamps mounted below the rear trim below the rear bumper. I have these wired through a pair of relays such that when I select reverse in daylight only the original reverse lights light up, when I have sidelights on the supplementary spot lamps also light in addition to the original.
You can't have enough light. Thumbs Up
If you fit supplementary lights I would recommend wiring them through a relay and not directly off the original wiring so that no problems arise. Switch the relay from the existing reverse lights wiring.
Post #362409 16th Dec 2015 7:41am
Robgosty
Just upgraded my reverse lamps with the G4 ones, picture below is a before & after, bulb on the right is the Hungarian 21w lens melter, (I added an extra rubber ring to prevent melting) on left is the G4 bulb, ordered bit from bay of E, literally is a ten minute job (as long as you can solder) snipped of the old bulb carrier and soldered on the new socket, bit of heat shrink over joint, all done, really good instructions earlier on in this thread, look better in real life than the pic, really bright & white, worthwhile mod.
Post #363495 22nd Dec 2015 3:53pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Well I liked the two sets of pcb's upgrade so I set about it,
The splitting of the units was so easy it's a surprise they don't fall apart Rolling with laughter
Finally got delivery from posty from China today Exclamation 3 weeks later Exclamation
So I decided to use push in bayonet holders from indicators as these with a small O ring fit perfectly into the rear of the lens.
I had some wired connector tails so will just upgrade the car wiring.
So here is some pic's before I go and fit them on the car Thumbs Up
 Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #363853 24th Dec 2015 2:10pm
Just a quick update, decided to fit three of the G4 LED lights to each side. EXCELLENT results Thumbs Up Pics below...
After checking all three lights worked i hot glue gun’d the wiring etc over the top so the vibration of closing the lower tailgate would not dislodge the plugs. Also bent the two outer tops over to gain more access to refit the light unit. Worked a treat Thumbs Up
Post #368165 20th Jan 2016 11:30pm
dognero
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Will these be ok?
Any better than stock
http://www.ebay.co.uk/itm/2X-H6W-434-BAX9S...1944224779
or maybe 4 of these
http://www.ebay.co.uk/itm/262513657775?_tr...EBIDX%3AIT
[url]
https://www.amazon.co.uk/ELINKUME%C2%AE-Br...+led[/url]
with these
http://www.ebay.co.uk/itm/262317458261?_tr...EBIDX%3AIT
Post #410088 21st Oct 2016 9:53am
anything is better than stock...pot luck which is brighter so you need to try them and see .. ... - .- -.
Post #410093 21st Oct 2016 10:08am
miggit
The biggest problem with those is there will only be enough room to fit 1 bulb per light..... and there is a restriction in the lens that will make it impossible to fit a large bulb, it wont go through the hole Shocked So your then limited to narrow bulbs that will be considerably less power than what is fitted at the moment Sad
The only way to get a decent light output is to split the light unit and fit the flat led panels.... it does sound quite daunting, but, in practice is a lot easier than it sounds Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #410095 21st Oct 2016 10:14am
markcartlidge
I added some of these to mine
Four per lamp
Works pretty well, might be a too bright in some cases.
Post #410112 21st Oct 2016 1:11pm
miggit
Whistle It can never be too bright when going backwards in the dark Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410125 21st Oct 2016 3:02pm
dognero
Ordered 4 of these and see what they are like.
Post #410252 22nd Oct 2016 9:48am
thats the ones i have in mine... Thumbs Up ... - .- -.
Post #410254 22nd Oct 2016 9:53am
miggit
Whistle That is spookie Shocked reckon I've used the same Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410338 22nd Oct 2016 10:43pm
