Home > Technical (L322) > Slow to engage first gear in morning. |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Many years ago I had a Ford Consul Uto that was exactly like that. I ignored it and it was fine for the whole time I owned the car ( maybe 30,000 miles). But, it produced a lot less power than a Rangie, and was worth less than the cost of a pint of ATF! |
26th Sep 2011 8:53am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
My Audi A5 used to do this if left standing for a while but happened in reverse also really annoying.. It only had 20k miles on it.The dealer did not appear too concerned oh how I hated that A5. They said it was just a valve that sometimes slow to engage if left standing or something like that .Just dont be tempted to do any bank robberies Present :2008 TDV8 HSE
26th Sep 2011 11:35am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
An obvious first assumption is that this is a hydraulic issue (fluid viscous when cold, drained back into the sump overnight, etc.). However, the fact that reverse gear engages immediately points away from this.
26th Sep 2011 11:46am |
There’s a guy over on Xoutpost.com http://www.xoutpost.com/bmw-sav-forums/x5-...sue-2.html who reckons he’s fixed his 1st gear engagement delay by replacing the fluid filter. Unlike in the 5HP24, where it’s held on by two screws, the 5L40-E filter is just a push fit into the seals in the suction port and he says that his came loose over time and dropped down into the sump.
27th Sep 2011 11:27am |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
That could be interesting. As I had the filter and fluid changed about 2000 miles ago. Maybe the new filter has slipped out. No longer FF owner but still interested. Present car Jaguar XE
27th Sep 2011 12:12pm |
ssgall Member Since: 05 Dec 2010 Location: North East Posts: 35 |
My td6 box has just gone.
27th Sep 2011 8:33pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Join the club, mine just cost me £2495 to replace! |
27th Sep 2011 8:38pm |
Clucking bell mate! Where did you get the recon box from and how much if you don't mind me asking? 2003 Vogue TD6 - Adriatic Blue - 2010 Facelift & 2010 20" wheels
27th Sep 2011 8:44pm |
Strange thing! The last few weeks the car is fine.
17th Dec 2011 11:09pm |
If its not used in manual mode maybe try flicking it into sport and then 1st and drive that way or a mile or two and then slot it back into Drive for the rest of the trip?? |
18th Dec 2011 9:04am |
m90got Member Since: 18 Oct 2011 Location: scunthorpe Posts: 120 |
my 2003 hse ffrr hesitated for the first time this morning when i reversed of the drive and then put it into drive,this is the first time it has done it but i have noticed a reluctance to change up at low revs unless i lift my foot of the throttle a bit,,
19th Dec 2011 2:15pm |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
M90 Its worth having your gear box oil drained,and having a new filter.
19th Dec 2011 3:55pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Thread Resurrection!
5th Jun 2014 1:01pm |
Ottar Member Since: 07 Jun 2016 Location: Bekkestua Posts: 8 |
This is getting old, but I have exactely the same issues. Will not engage in D for 2-4 seconds in the morning. Everything perfect besides this.
20th Oct 2016 11:07am |
