Home > Technical (L322) > Slow to engage first gear in morning. |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Further to my post. Transmission fluid and filter were changed about 2,000 miles ago, so I assume it was filled correctly. Mileage 94,000. No longer FF owner but still interested. Present car Jaguar XE
31st Aug 2011 11:04pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
We have had experience of boxes not being filled correctly and failing quickly soon after! Also boxes which have not been saved in time, by changing the oil and have failed soon after... Sorry!!! |
1st Sep 2011 7:04am |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
Gearbox knackered..
1st Sep 2011 7:26am |
Always worth checking the Gearbox Linkage is not corroded/sticking!
1st Sep 2011 7:29am |
10/10 for persistance Gaz |
1st Sep 2011 7:59am |
1st Sep 2011 8:04am |
...and the cure for a flat battery is.....
1st Sep 2011 8:11am |
You guess it
1st Sep 2011 8:22am |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
True. But unfortunately for Mikey, I have to agree with Paul (though he didn't need to rub it in by repeating it ). This is a TD6 - and a classic symptom. Though it doesn't have to be in 2000 miles - could go another 10+k. As of a certain point, it's better to leave the old fluid than have it changed. Having the fluid changed actually seems to speed the gearboxes demise But - how do you know if you've reached that point? Do follow Craig's advice and have the fluid level checked. Needs to be checked at the proper temp with a T4 or an infrared thermometer! RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
1st Sep 2011 8:27am |
Ok guys. Further to my original post, I just havent had the time to get it looked at recently, also due to various commitments I don't have the ready cash to pay for a major outlay such as a possible new gearbox.
25th Sep 2011 7:14pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
The difference between engaging Manual 1st and Drive 1st is the low & reverse clutch is engaged in ‘manual’ which bypasses the low clutch sprag (to provide overrun braking). This could indicate that you have a problem with the low clutch sprag.
25th Sep 2011 9:52pm |
Thanks for that info. If that turns out to be the problem, how expensive is something like that going to cost? Is it likely to fail suddenly or last a little while? Would it easily be diagnosed by a decent auto box repairer? Sorry for all the questions. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
25th Sep 2011 9:57pm |
Rangie in oz Member Since: 25 Jul 2010 Location: liverpool Posts: 52 |
Hi mike, can't help with the cost but mine has done this since I've had(18mnths) it, had the oil changed ect but no difference at all, I've done over 60k like this but as im aware of it I don't rev it in the morning but just let it drop in gear, can take 30 to40 seconds when cold, its ok when its hot. Reckon it would go downhill quick if i tried to pull away before it went in in the mornings. Im sure it will tell me when it needs attention. Its never got any worse in the last 60k klms Hope this experiance helps. Neil 03 TD6 vogue....Epsom, very nice 03 TD6 se....gone 94 Vogue se....gone |
26th Sep 2011 8:32am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
mikey , mine does that if its been standing for a few days, its no problem , all you do is fire up the range , adjust the radio volume to suit, adjust heat/cold/fan to required settings,put on seatbelt, stick your finger in your ear take out and see what's on the end of it, look into reverse mirror and tell yourself your a lucky git to have a range, and by the time you've done all that the auto box would be ready for 'drive' engagement... ... - .- -.
26th Sep 2011 8:38am |
