Home > Maintenance & Mods (L322) > has anyone ever mod'ed front indicators ? |
Lukie, hopefully this thread will assist
7th Oct 2016 8:29pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
Sadly my l322 is the earlier pre face lift with separate indicator |
8th Oct 2016 8:02am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1379 |
Generally as long as you get canbus led bulbs then there isn't a need for ballast resistors ( that I've found so far ) V8 or else ... |
8th Oct 2016 8:57am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I did a bit of modding to mine ...
15th Oct 2016 9:11am |
did verydisco Photoshop the last image with no amber inserts ?
29th Oct 2016 10:09pm |
Yes last image is photoshopped, i did buy an old cluster and tried to open it up but i think the only way would be to use a mini circular saw on a dremel and cut it open but would need to keep it cool with water as the plastic just melted when i tried but i did use an abrasive wheel rather than a saw with teeth. i have seen a few write ups on the L405 conversion to the L322... |
30th Oct 2016 7:15am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'll save you some
30th Oct 2016 10:05am |
Found the little 's
30th Oct 2016 10:18am |
Do the lenses come out from the back then, i can't remember?
30th Oct 2016 5:39pm |
It's rather involved to get at the blighter's.....
31st Oct 2016 12:11am |
Blow that, i tried separating the outer cover when i looked into painting the internals black and opted to painting the outside instead.
31st Oct 2016 6:44am |
They are a pain, look at most other cars including x5's you can get an array of after market lights Leds creeds fronts and backs, range rover pretty much nothing apart from side indicators |
31st Oct 2016 11:26am |
I'll have to get the dremel out again when i run out of jobs to do........... |
31st Oct 2016 7:02pm |
