![]() | Home > Maintenance & Mods (L322) > Java Black 2002 |
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
Does anyone know part number for body side part for the last clip on sill moulding? Cannot find it from microcat. |
Looks suprisingly rusty. Specially when everything is covered with plastic and there is no mechanical influence on these surfaces. |
It seems that some welding is needed after all.
I couldn't find the bottom piece from parts catalogue. |
Ended up doing this from three parts.
And after some welding exercise pieces are now part of the car. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Not shy of a bit of work, looks a good job, and should last at least as well as the original panels...... There is nothing that can't be fixed with a hammer😜😜
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Bodywork always impresses me. I know it isn't rocket science and I should learn it someday. |
Definitely not rocket science. Closer to witchcraft in my opinion. |
As you can see I'm not Harry Potter. |
Finally on the road. Here waiting MOT inspection. |
Steering wheel straightened and wheel speed sensor connector from right rear was lubricated with wd40 (fault code found with INPA from DSC) and fault lights have not appeared again. |
Short measurement session with multimeter and result is LUC solenoid having open loop at gearbox connector. Need to source new or second hand solenoid. |
