![]() | Home > Maintenance & Mods (L322) > Java Black 2002 |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
In order of expense and hassle I would address your LUC issue in the following order:
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
Hello everybody,
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
You don't need to be RRPHIL to know that piece doesn't belong there. |
When comparing 95 and 02 valve bodies 1058.427.022 I noticed quite a few changes. I guess it would unwise to mix those parts. |
Yes, for sure, the only way that’s got in there (without going through the filter first) is from inside the torque converter.
I wonder where my spare valve body is originally from? Solenoid block has cast number 1055.427.105 and stamp 312. Year is 95 and EDS1 is green. It was taken from 1058 000 023. Clearly not original valve body.
RRPhill you are a master! |
Yes, something not quite right there. That looks like a 5HP30 valve body assembly to me (1055 127 312). The valve bodies fitted to the 5HP24 in the BMW/Alpina E38 730d (i.e. your 1058 000 023 transmission) were the same as the Range Rover ones. Phil |
It is very strange indeed. Bought it from eBay and seller told it was pulled out from 730d. Are 5hp30 and 5hp24 valve bodies interchangeable? Some parts seem to be at least. |
Strange why somebody would do that. 1055 part numbers are 5HP30 and 1058 numbers are 5HP24. If your lower rear (solenoid) valve block from the ‘023’ transmission has a 1055 number cast into it then somebody, for whatever reason, has swapped this over from a 5HP30 at some point |
And all parts are from 1995 except solenoids probably. Couldn't find time stamp from those.
Yes, possible I suppose - the two valve blocks are certainly very similar. If the castings are marked with a ‘95’ production date, though, they definitely aren’t from a 730d transmission because the first ‘023’ unit rolled off the production line in March 1998 |
After thorough cleaning everything is now back together and it actually works. |
1000km test run behind. 80kmh speed mpg was showing 12.0l/100km. In reality it is closer to 13l/100km.
