Home > Maintenance & Mods (L322) > Java Black 2002
Page 2 of 5 <12345>
kimlahti
Finland 2008 Range Rover Vogue TDV8 Alaska White
Haylands wrote:
The links to the before and after covers don't work
Damn you Microsoft. Evil or Very Mad I downloaded them from those links and attached to forum gallery (used ipad). That seems to work also from phone(lumia925). I need bigger phone. Twisted Evil Here they are.
Before:
After:
 -08 3.6 Vogue
-87 951
Post #398196 29th Jul 2016 9:42am
kimlahti
Old converter was made in Germany by Sachs and new was just made by Sachs. Couldn't find any time stamps. Took off the oil pan and filter. Less shavings in magnets than 730d had with exploded a-drum and cracked valve body. Well RR moved 10m back and front without jerks or other abnormal activity. Very Happy That is the longest test drive I have had with it. What I am worried that there was some aluminium chunks in the pan. Is that omen of nearing catastrophy?
Filter had only this stamp. No other markings. Maybe model number more than time stamp?
 -08 3.6 Vogue
-87 951
Post #398201 29th Jul 2016 10:03am
Looks better than mine did last time I changed the oil..... Whistle Whistle
Cam covers look good, mine are on my "to do" list.... :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #398206 29th Jul 2016 10:33am
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Mine didn't have many fillings either but I did find a piece of plastic under the magnet and no ideas where that came from 😳 2004 RR 4.4 V8 Autobiography
Post #398217 29th Jul 2016 10:50am
johnboyairey
paulM -post the picture of the piece of plastic from your sump.. your chain guides are made of plastic.
you might want to consider removing the small dif/sump protector, and remove the lower sump. maybe witha gasket to hand.... this will tell you if you have any major chain guide plastic parts, too big to exit the sump drain plug. they are a white nylon colour.
not trying to alarm you, just inform you..
Post #398257 29th Jul 2016 2:22pm
John, not in the gearbox, surely....?? Pete
Post #398308 29th Jul 2016 6:32pm
johnboyairey
ooops, no not the gearbox. -was having cam-chain-flash-backs, and it all went a bit wishy-washy.
Post #398314 29th Jul 2016 7:23pm
kimlahti
Valve block seems to be ok. No crack visible in the usual place. Smile
I guess it is time to put everything together and see how it works. Very Happy -08 3.6 Vogue
-87 951
Post #398366 30th Jul 2016 10:07am
PaulM
I hope I don't have any chain guides in my gearbox Shocked 2004 RR 4.4 V8 Autobiography
Post #398462 30th Jul 2016 8:43pm
kimlahti
Laughing -08 3.6 Vogue
-87 951
Post #398466 30th Jul 2016 9:05pm
kimlahti
It works! Very Happy Runs so quietly that whining power steering pump needs to be addressed next. Rolling Eyes
Renewed o-rings to coolant hose connectors but forgot the note in garage. Need to write size of those here before that piece of paper is lost. Laughing -08 3.6 Vogue
-87 951
Post #399887 10th Aug 2016 7:26am
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
There is a guy on eBay that sell a kit with all the O rings for the RR and other cars. He is in the US. Kit was cheaper than buying individually. Incredible job guy.
Post #399941 10th Aug 2016 2:26pm
kimlahti
That's good to know. I couldn't find him from eBay. Bad search keywords I guess. Very Happy
Here is what I know about those o-rings.
Top/Bottom coolant hoses. 38x4mm (4pcs)
Smaller hoses to transmission oil cooler 16x3mm (5pcs)
Alternator connectors 12x3mm (2pcs)
Rest were untouched so I didn't change those. Lazy. Rolling Eyes Hose in back of the engine with o-ring was renewed so that size was not measured. -08 3.6 Vogue
-87 951
Post #400067 11th Aug 2016 7:06am
johnboyairey
If your arms still have some strength, then, reach round, and pat yourself on the back, whilst you fill the fridge with rewarding beers.
You've done a great job there. And you know that your work, will give you piece of mind, and a smile every time you get in the car.
I did the chain guides, and vanos seals, along with a tidy up, all in situ. And now my valley pan job seems all good now too.
My engine still sounds sweet, and still quite clean looking. With 25k extra miles since.
Enjoy your Rangie. -you will soon realise that there is no other car, that comes close!
Post #400087 11th Aug 2016 11:16am
kimlahti
Thanks guys. Cool Back patting has to wait until overdue MOT inspection is passed. Laughing
There is still something to do before that.
- rear brakes (disks, pads, shoes, hoses)
- overall corrosion check on rear underside. Front was quite well oiled. Very Happy
- rear diff oil change
After MOT jobs:
- cleaning
- drivers door card leather repaint
- more cleaning
- steering wheel painting
- drivers seat leather painting (possibly)
- upper tailgate corrosion fix (hide&slow down)
- ignition lock wants some lubrication
- middle console cup holder wont lock down
- cd changer to something better
- reversing camera (had that in P38 and can't imagine life without it) Mr. Green
- and all those extra tasks that are found in inspection. Laughing -08 3.6 Vogue
-87 951
Post #400096 11th Aug 2016 12:18pm
Page 2 of 5 <12345>
