![]() | Home > Maintenance & Mods (L322) > Red oil coming out of zf 5hp24 gearbox |
Andy K Member Since: 06 Jun 2016 Location: GL Posts: 48 ![]() ![]() ![]() |
This amused me.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
http://www.fullfatrr.com/forum/post368837.html#368837 Phil |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Thanks RRphil. This is interesting about the Pentosin. I stayed away from it in the past because somewhere on one of its info sheets it implied it was a substitute for LT 71141. Perhaps it's a lost in translation thing. This sheet pretty much says the two are the same product. I will try another approach with liqui-moly and Febi and ask how they differ from Pentosin. I would love to have a real clear understanding of the products so I can decide if one is truly worth 50% more or just maybe needs a bit more frequent change. |
Here�s the Technical cover sheet for the Range Rover �032� 5HP24 transmission from ZF�s Service Data Management software showing Pentosin ATF 1 as the correct fluid.
TE-ML11 still shows Lifeguardfluid 5 as being the right fluid
and this has remained unchanged for years now. ZF Lifeguardfluid 5 and Pentosin ATF 1 are not particularly easy to get hold of in the UK and so Mobil ATF LT71141 is the easiest and cheapest of the fluids to source over here. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
As I've said in my other post I've been using the Febi brand. Transmission has just gotten better. I have a 2000 mile round trip starting tomorrow. When I get back I will change the filter for a second time in 17k miles and the pan fluid 4 times in 17k miles. It is starting to get clean.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
The life of the oil at given operating temperature is what we need to be concerned about.........this is where the ZF approvals come into the equation.
OK Phil in your other thread you felt esso /Mobil/lifeguard/pentosin were all the same. My understanding is that pentosin is fully synthetic. I can't find info on ZF lifeguard. Mobil/esso are semi synthetic. Would it be safe to say the Pentosin is the improved version of 71141? |
There is controversy by some that if the tranny is very dirty a complete flush can dislodge that crud and cause it to plug ports, pumps and solenoids. Seems like a plausible idea. If true this could be the cause of some trannys going bad shortly after the first overdue fluid change. If this is true it would also mean that the fluid and filter have reached the maximum amount of suspended particles leaving the rest of the crud stuck to walls. Just changing the filter and pan fluid would leave half the particulate saturated fluid allowing for a more gradual release of any clumps into suspension and hopefully collected by the new filter. Just a theory.
I guess it depends on the system layout.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
personally I would cycle through 3-4 oil and filter changes over a few months, this as said will let any more particles stick in the new filter. After that the original oil should be so dilute as to not be a real problem.
I think once I see fairly clear fluid I would have that option. |
Thanks for your e-mail.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Still mentions nothing about any additives...
I think his reply covers it here
