Home > Maintenance & Mods (L322) > Red oil coming out of zf 5hp24 gearbox |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
It's how they classify oil..... yes it is equivalent oil, and is compatible with the correct oil BUT it doesn't have the necessary additives to protect the 5HP24....
27th Jul 2016 1:30pm |
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 |
27th Jul 2016 3:42pm |
27th Jul 2016 3:43pm |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Anyone have the spec and data sheet on Mobil LT 71141? Like to see how it different from other label LT 71141 products. |
27th Jul 2016 6:27pm |
There is only one Mobil LT71141, that stuff you linked to says it's compatible with it and it is, it won't harm it at all... it doesn't replace it though... don't think Mobil will tell you what additives the oil has, it was made for ZF specifically for the 5HP24 when they decided to have the (IMHO potty) slipping TC to smooth the gearchanges....
27th Jul 2016 7:02pm |
No disrespect meant here but if we don't know what is in it you/we can't know if another company has licensed or copied the identical formula. I emailed liqui-moly regarding their product. They have 2 categories for this equivalent. The fact that the ZF 5hp24 is not listed under the approvals section concerns me.
27th Jul 2016 9:29pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
I did look into this prior to making a decision some years ago.
28th Jul 2016 12:11am |
Its all cool Doclees, a good debate is, well good. Your concern that our trans is not on the list is nullified. All the ZF approvals are at the end of the list; ZF TE-ML 02F ; ZF TE-ML 03D ; ZF TE-ML 04D ; ZF TE-ML 05L ; ZF TE-ML 09 ; ZF TE-ML 11A ; ZF TE-ML 11B ; ZF TE-ML 14A ; ZF TE-ML 14B ; ZF TE-ML 17C The one that concerns us is; ZF TE-ML 11A www.zf.com/global/media/en_zf/lubricantslists/TE-ML_11.pdf |
28th Jul 2016 12:24am |
I found this for more clarity and confusion.
28th Jul 2016 2:44am |
Yes I see what you mean re the Mobil product, it doesnt have the 11A (which the Top Tech 1200 Liquimoly) rating, which gives it the thermal stability from what I read of it.
28th Jul 2016 9:00am |
I appreciate what you are saying, and if it works for you and your happy with it then great....
28th Jul 2016 9:06am |
This is the response I got from liqui-moly.
28th Jul 2016 12:13pm |
Ask him to guarantee that it has exactly the same additives as LT71141, be interesting to read his reply.... as I said, they will say anything because you can't prove otherwise.... it is not any ones job to ensure that their claims are true....
28th Jul 2016 12:37pm |
So as i do more research it gets more convoluted. I go to Exxon/mobil to find info. They do not list 71141. Not a US product. Seems to me if ZF only wanted Mobil brand 71141 in there transmissions that is what you would find in the dealerships. Then again they said it was a sealed for life transmission.
28th Jul 2016 3:56pm |
