Home > Technical (L322) > reduced performance
Page 1 of 3 123>
Terrier
reduced performance
Warning on dash today, reduced performance! Car temperature ok, weather hot, climate blasting out.
I stopped her, locked her, Unlocked her and set off again up the A1 following a truck (48.9mpg) and it was fine. Warning lit up again near home as I asked for some revs coming uphill.
Any ideas chaps, other than to get her looked over?
She's a 2011 Vogue with just under 60k.
Thanks in begrudging anticipation.......
Post #396630 18th Jul 2016 5:07pm
kbald
Could be split hoses if it happens underload. I'm assuming it's a diesel?? Were there big clods of smoke coming out of the back when it happened?
Post #396633 18th Jul 2016 5:26pm
Terrier
No, nothing like that. I did notice a little water discharge underneath however I put that down to air con.
Post #396635 18th Jul 2016 6:06pm
n1cktdv8
Get it plugged in to diagnostic soon as you can. Is this where I put the car details and a bit about myself ?........
Post #396639 18th Jul 2016 6:41pm
3.6?
If so typical split hose symptoms. Thumbs Up dead easy to sort look at the wiki for how to repair a split hose and check for leaks. Thumbs Up
The plastic intake manifold can split on the 4.4 which can cause a similar result to a split hose on the 3.6. There is nothing that can't be fixed with a hammer😜😜
Post #396640 18th Jul 2016 6:41pm
Terrier
Apologies chaps, she's an oil burner TDV8
Post #396643 18th Jul 2016 6:50pm
3.6 or 4.4 ?
As NMJ states - on a 3.6, this message is often down to a split intercooler hose.
If you accelerate hard & look in your mirror you should see black smoke which is usually the give away.
Post #396644 18th Jul 2016 7:00pm
GraemeS
If its a 4.4 and still has the original secondary turbo inlet isolation valve then the valve could be sticking.
Post #396645 18th Jul 2016 7:05pm
kbald
5 minute job to check them and you only need a screwdriver. Have a search on here loads about it. If they are fine atleast you can rule them out without paying someone to check these for you!
Post #396646 18th Jul 2016 7:05pm
Terrier
You're in Leeds, fancy a pint? Thumbs Up
Do you mean check the hose mate or the secondary inlet valve thingy?
Cheers
Post #396649 18th Jul 2016 7:12pm
Is it a 3.6 or 4.4 Rolling Eyes
Rotary gear selector or classic gear selector ?
Post #396651 18th Jul 2016 7:14pm
kbald
It's certainly the weather for a pint or 3 that's for sure!!
Depends which engine it is as to which problem it could be! Both v common
Post #396657 18th Jul 2016 7:25pm
Terrier
4.4 TDV8 rotary knob
Post #396658 18th Jul 2016 7:25pm
Terrier
You're not wrong, I've just lifted the hood and she's still red hot and I've been home since 5:30.
It's very busy under there. My good lady took a look and said "everything looks ok". So that's that then!
Post #396660 18th Jul 2016 7:29pm
This thread might help - I don't know much about the 4.4's (even though I have one Embarassed )
Post #396662 18th Jul 2016 7:31pm
Page 1 of 3 123>
