Home > Technical (L322) > reduced performance |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8650 |
There is a turbo blend valve type thingamy which has been known to fail. There is an updated part.
18th Jul 2016 9:07pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7954 |
18th Jul 2016 9:12pm |
This one
18th Jul 2016 9:13pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Gents...OP states 2011 TDV8 in his original text Is this where I put the car details and a bit about myself ?........ |
18th Jul 2016 9:31pm |
Need to learn to read properly |
18th Jul 2016 9:36pm |
True enough, though I thought there may be a few 3.6s out there on 11 plates..... In any case the link to the thread above describes one possibility There is nothing that can't be fixed with a hammer😜😜
18th Jul 2016 9:46pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
I posted a thread called 4.4tdv8 restricted performance some time ago, which describes exactly the same symptoms.
19th Jul 2016 7:22am |
Terrier Member Since: 17 Dec 2015 Location: Yorkshire Posts: 51 |
I think I've got a link to it above Baltic thanks.
19th Jul 2016 7:31am |
Get the 4 short turbo inlet hoses checked at the same time.
19th Jul 2016 7:53am |
Apologies, I missed the word happened out of my sentence.
19th Jul 2016 9:53am |
Sorry, far too cryptic for my simple brain.
19th Jul 2016 10:01am |
Doh, clearly I know more about football than full fats.
19th Jul 2016 5:19pm |
Just to update, it's believed to be a split hose, one of the 4 hoses which run in an around the turbo. I'm having all four replaced whilst they're under the bonnet, £240 + VAT.
20th Jul 2016 3:53pm |
MartSim73 Member Since: 12 Oct 2015 Location: Wimborne, Dorset Posts: 53 |
Hi Terrier.... Can I make a further suggestion to save further cash and worry down the road?... I too have a my11 4.4tdv8. I had split hoses and had them replaced. I also had DPF failure due to the crud and oil based around the same problem. However, having sorted all that back in January, the car was a little hesitant, not knowing whether to go up a gear or down when you wanted or needed to plant your foot.... Well, that's how it felt.
21st Jul 2016 4:40pm |
