Home > Maintenance & Mods (L322) > Tailgate open = battery flat |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3829 |
When sitting on the tailgate for a short while the battery invariably goes flat, is it just the interior lights coming on or something else. Obviously I can disconnect them or change to LED but is there something else? Geoff |
8th Jul 2016 10:08pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8284 |
Changed 19 interior lights on mine for LED's... leave the doors open for as long as you like now....
8th Jul 2016 11:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I've got to do what Pete's done. However with incandescent bulbs the voltage will drop below cranking capacity before the lights dim to nothing. ______________________________
9th Jul 2016 1:52am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
You can turn your interior lights off with tailgate open with your iiDTool and then only the one light in the back comes on 2008 MY Supercharged
9th Jul 2016 2:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
you can switch the lights off by pressing the main front button for a few seconds and it will flash to acknowledge ...switch back on the same way.. ... - .- -.
9th Jul 2016 5:19am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Your battery is on its way out.
9th Jul 2016 6:10am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
Interior lights should switch off after a number of minutes, tells you in the handbook. I removed the boot lights in my old td6 though as they never went off. |
9th Jul 2016 7:31am |
It's 16 minutes and the lights turn off, along with the rest of the car going to sleep, it ignores an open door or boot thinking you made a mistake and tries to save the battery... Pete
9th Jul 2016 10:13am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Press and hold the front interior light button as Stan says it will disable he lights.
10th Jul 2016 4:50pm |
Normal battery, is the AGM one just a straight swap - any recommendations? Geoff |
10th Jul 2016 7:14pm |
Not a straight swap as the charging cycles and voltages are different. Afaik. I think it can be changed in the ccf though would see if it was part of the LR scheme and you may get it done for you. There is nothing that can't be fixed with a hammer😜😜
10th Jul 2016 7:39pm |
