![]() | Home > Maintenance & Mods (L322) > Tailgate open = battery flat |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3889 ![]() ![]() ![]() |
When sitting on the tailgate for a short while the battery invariably goes flat, is it just the interior lights coming on or something else. Obviously I can disconnect them or change to LED but is there something else? Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8519 ![]() ![]() ![]() |
Changed 19 interior lights on mine for LED's... leave the doors open for as long as you like now....
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I've got to do what Pete's done. However with incandescent bulbs the voltage will drop below cranking capacity before the lights dim to nothing. ______________________________
You can turn your interior lights off with tailgate open with your iiDTool and then only the one light in the back comes on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35621 ![]() ![]() |
you can switch the lights off by pressing the main front button for a few seconds and it will flash to acknowledge ...switch back on the same way.. ... - .- -.
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Your battery is on its way out.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Interior lights should switch off after a number of minutes, tells you in the handbook. I removed the boot lights in my old td6 though as they never went off. |
It's 16 minutes and the lights turn off, along with the rest of the car going to sleep, it ignores an open door or boot thinking you made a mistake and tries to save the battery... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Press and hold the front interior light button as Stan says it will disable he lights.
Normal battery, is the AGM one just a straight swap - any recommendations? Geoff |
Not a straight swap as the charging cycles and voltages are different. Afaik. I think it can be changed in the ccf though |
