![]() | Home > Technical (L322) > 2003 Td6 Fueling issue |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hiya , Looks like you have covered the loom side quite well, would it be an option to swap an injector and see if it moves the problem?
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
I have considered this , as I still have my other injector that was leaking back but ran ok. I have found a specialist diesel garage near me so I am going to get them do some diagnosis rather than dive straight in and change bit by bit , hit and miss |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
Sounds like the typical td6 injector failure, many threads on here about it. '55 Java Black Vogue |
SidewaysMatt Member Since: 24 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
Mine had the same symptoms a couple of weeks ago, cured by replacing 2 injectors. 2004 Vogue TD6 - Remapped |
I have changed No1 injector before and that did not require the inlet manifold removing.Question is , if I obtain a new injector and do it myself , do you require a new manifold gasket when rebuilding it all again ? Looking around for an injector , and if its listed for the BMW X5 the prices seem a lot less than if it says Range Rover in front of the description - especially on E bay anyway |
Not sure about the manifold gasket, due to lack of time, got a garage to do it. However as far as sourcing injectors, was given the heads up on here about Diesel Jones (P F Jones) in Manchester. Rebuilt injectors are £96 on an exchange basis. They delivered next day too. 2004 Vogue TD6 - Remapped |
Not sure about rebuilt/refurbed injectors (I have my old one for refurbing). I can get a new one for 130 so to put an old one back in for 30 pound less , how much mileage before problems again ? Getting a warranty with them is fine but I would only want to do the job once |
fogotter Member Since: 01 Mar 2016 Location: hull Posts: 24 ![]() ![]() ![]() |
I have exactly that problem and you have described the symptoms to a tee, I had a knackered injector which was fine until you gave it some power then it shook. New injector cleared it up. |
