uses next to no fuel, so i wouldn't worry about that. I use mine on the disco every cold morning with a remote from the bedside
Have you checked it actually works. Its a bit tricky to try in summer as the electronics won't let it turn on unless the temp is below 16deg.
If you don't do at least 15 min journey after using it then repeat uses will drain the battery, it is quite power hungry, the battery will charge obviously but if you as only doing short commutes then it will eventually not start at all. So prudent use is recommended. In really cold conditions it will take the chill off the cabin and start to defrost the screen, in cold conditions it is quite nice and toasty in the cabin. As there should also be a heated screen then it gives that a bit of a headstart.
No it won't help with the fuel turning to jelly in super cold conditions, but not a lot will..... you can't light a fire under the tank, you will just set light to the car. There is nothing that can't be fixed with a hammer😜😜
