Home > Technical (L322) > 2003 Td6 Fueling issue
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Drove my car and went for a 50 mile ride to work. On reaching the entrance barriers to work , when slowing , the car began to 'jerk' quite violently. Also did the same in reverse when parking up. However , whilst fretting all shift about how it would be at 2200 hrs to drive home thinking gearbox, recovery etc , to my surprise , it drove faultlessly ! Went out yesterday and started to do the same again , so gave it a boot and it also came in at 50-60 mph ! When stopped I opened the bonnet and you can see the engine 'shaking' at idle , so this confirmed the fault was not the gearbox ! Very Happy
Today , when cold I started the car and again you could see the engine was 'missing' on one cylinder. Took all covers off to access the injectors and wiring loom and by removing and replacing one injector plug at a time I have found it is No5 cylinder that is not working. I have checked the continuity at the injector with No1 injector and the readings are comparible (40 ohms - No1 was new 2 years ago due to leaking back and making the car hard to start). Did a continuity test of the wiring loom after tracing the correct feed cables and this also seems to be ok with good continuity. The wiring loom itself looks like new with no cracking or chaffing etc. I have tested the supply voltage from the ECU to the injector at the ECU end whilst running and I get 9.6v DC . I have put injector cleaner in over the last month , but as the injector does not seem to be firing will obviously have no effect. My question , as I have no dedicated Range Rover diagnostic software , is :- New injector (which I am edging towards) or a new wiring loom ? I would appreciate and comments , advice re this conundrum Smile Oh , the car has done 157k miles Smile
Post #395221 9th Jul 2016 1:57pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hiya , Looks like you have covered the loom side quite well, would it be an option to swap an injector and see if it moves the problem?
Good luck
Simon
Post #395232 9th Jul 2016 2:41pm
mercs600
I have considered this , as I still have my other injector that was leaking back but ran ok. I have found a specialist diesel garage near me so I am going to get them do some diagnosis rather than dive straight in and change bit by bit , hit and miss Thumbs Up
Post #395249 9th Jul 2016 3:46pm
Nicka2311
Scotland 2005 Range Rover Vogue Td6 Java Black
Sounds like the typical td6 injector failure, many threads on here about it. '55 Java Black Vogue
Post #395300 9th Jul 2016 9:16pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine had the same symptoms a couple of weeks ago, cured by replacing 2 injectors. 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #395331 10th Jul 2016 9:52am
mercs600
I have changed No1 injector before and that did not require the inlet manifold removing.Question is , if I obtain a new injector and do it myself , do you require a new manifold gasket when rebuilding it all again ? Looking around for an injector , and if its listed for the BMW X5 the prices seem a lot less than if it says Range Rover in front of the description - especially on E bay anyway Smile
Post #395350 10th Jul 2016 11:03am
SidewaysMatt
Not sure about the manifold gasket, due to lack of time, got a garage to do it. However as far as sourcing injectors, was given the heads up on here about Diesel Jones (P F Jones) in Manchester. Rebuilt injectors are £96 on an exchange basis. They delivered next day too. 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #395409 10th Jul 2016 8:21pm
mercs600
Not sure about rebuilt/refurbed injectors (I have my old one for refurbing). I can get a new one for 130 so to put an old one back in for 30 pound less , how much mileage before problems again ? Getting a warranty with them is fine but I would only want to do the job once Smile Fortunately the Range Rover is not my everyday car (only did 1200 miles last year) , so If I do require a manifold gasket I can order one and wait for it to arrive as its not a VOR (vehicle off road) situation Wink
Post #395432 11th Jul 2016 8:23am
fogotter
United Kingdom 2003 Range Rover Vogue Td6 Alveston Red
Same issue
I have exactly that problem and you have described the symptoms to a tee, I had a knackered injector which was fine until you gave it some power then it shook. New injector cleared it up.
Post #395466 11th Jul 2016 10:51am
