![]() | Home > My Range Rover > My £4,600 TD6 Project |
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 ![]() ![]() ![]() |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 ![]() ![]() ![]() |
Looks great |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
It's looking great, but has it been re mapped yet? and does it go as good as it looks? And do your engine mappers have a rolling road so that you can get an accurate power reading |
joeypineapplez Member Since: 27 May 2015 Location: Waterford Posts: 68 ![]() ![]() ![]() |
Excellent job. I agree with you about the android unit. One of the first things I did. As regards the injector nozzles and the engine sounding different. Is it any quieter/less agricultural.? And may I ask where you sourced them.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8357 ![]() ![]() ![]() |
Looking good, so how much did it cost to get there from when you bought it...??? Pete
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
any news on that project?
Hi Clemenz. ...Performing superbly...front driveshaft splines failed alright as the car never had its recall, but it now has its upgraded front diff plange and driveshaft with CV joint...Other than that it's been 100% reliable. Transmission and torque converter are excellent 2008 Range Rover TDV8 435,000kms
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Lots of works involved indeed. Did you end up painting the lower bumper trim?
Yes update on total cost please ?
Welsh Walrus Jones Member Since: 10 Oct 2015 Location: Mountain Ash Posts: 18 ![]() ![]() ![]() |
Hello All. Trust well. Good to see you are pulling well. I remapped the engine using the BMW X5 chip making it far better in changing throughout the gear range but also in fuel consumption. Cost was around £400 fitted. However, in a non-related matter have the dreaded "Transfer box neutral" showing and now coming persistant. Have noted when you take time with the engine off, just the ignition switched to position 2, it can change happly from high to low range and back again. So all ok until you start it up 5 mins later and it "dings" again. Why does it do that? I have a feeling it is one of the ECU's or even a lose connection somewhere as the sat nav screen is also going green! Thought, I mention this as in a muddy field with a box in tow they say to start in low range and also if anyone can offer their kind advice to me. By the way, happy towing and thanks for your time. |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
Hi Riverstick
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
subscribed while reading all the info. I may go this route with my td6. |
