Home > My Range Rover > My £4,600 TD6 Project
Page 9 of 9 <123456789
hgbosch
South Africa
Welsh Walrus Jones wrote:
Hello All. Trust well. Good to see you are pulling well. I remapped the engine using the BMW X5 chip making it far better in changing throughout the gear range but also in fuel consumption. Cost was around £400 fitted. However, in a non-related matter have the dreaded "Transfer box neutral" showing and now coming persistant. Have noted when you take time with the engine off, just the ignition switched to position 2, it can change happly from high to low range and back again. So all ok until you start it up 5 mins later and it "dings" again. Why does it do that? I have a feeling it is one of the ECU's or even a lose connection somewhere as the sat nav screen is also going green! Thought, I mention this as in a muddy field with a box in tow they say to start in low range and also if anyone can offer their kind advice to me. By the way, happy towing and thanks for your time.
Hi Welsh Walrus Jones
that TFC problem of yours is the potentiometer inside the transfercase shift motor. Unfortunately those gizmos are not available loose, so you will have to bite the bullet and buy a new motor. You can source from LRParts Direct or OEM.
https://www.lrdirect.com/IGH500010-Motorasy/
kind regards from South Africa
George
Post #396431 16th Jul 2016 10:01pm
Jones S13
Only just joined the forum, just read this thread start to finish. Fantastic work, great to see somebody modifying a car like this rather than just trading up.
Post #396479 17th Jul 2016 1:32pm
Jones S13
double post Rolling Eyes
Post #396480 17th Jul 2016 1:32pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
What is that android head unit and where did you get it? 2004 RR 4.4 V8 Autobiography
Post #398933 3rd Aug 2016 12:12am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
Any news on your project?
Post #436474 30th Apr 2017 3:14pm
