Home > Technical (L322) > Tiny Fan in HEVAC panel ..... Highly likely the culprit! |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1537 |
This thread says it does shut down after a few minutes: http://www.rangerovers.net/forum/6-range-r...-02-a.html Ron B. VK2OTC
12th Jun 2016 7:24am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
A few minutes maybe 5 then it stops. |
12th Jun 2016 2:21pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
Clivefog
12th Jun 2016 4:50pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Lenb,
12th Jun 2016 5:41pm |
Nicedayforit
12th Jun 2016 5:59pm |
Ok
12th Jun 2016 6:52pm |
The only way to systematically find a battery drain is to connect an ammeter in series with the battery positive terminal and then pull fuses one at a time until the drain drops to almost zero. When you find the fuse where the drain is you have found the circuit causing the issue. That will give you an idea of where to look next |
12th Jun 2016 7:00pm |
I did have an old Nokia phone in there, afraid I was lazy and just 'snipped' the wiring
12th Jun 2016 7:01pm |
Regarding the phone.
12th Jun 2016 7:13pm |
I will give that a look, although I've looked for water ingress and can't find any (the TV has stopped working though). Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
12th Jun 2016 7:16pm |
Re the TV, the screen is blank or noisy? My TV doesn't work but that's because it's analogue and TV here is now digital. Ron B. VK2OTC
12th Jun 2016 9:55pm |
The TV caused the display to go blank 12 months ago. I bypassed the TV and got the screen back. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
12th Jun 2016 10:07pm |
Since removing fuse 12 (HEVAC control panel) I've regularly checked battery voltage and made notes:
15th Jun 2016 8:47am |
You could certainly switch the mini fan and for that matter the heater/ac fan by simply replicating removing Fuse 12.
15th Jun 2016 9:14am |
