![]() | Home > Technical (L322) > Tiny Fan in HEVAC panel ..... Highly likely the culprit! |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1561 ![]() ![]() |
This thread says it does shut down after a few minutes: http://www.rangerovers.net/forum/6-range-r...-02-a.html Ron B. VK2OTC
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
A few minutes maybe 5 then it stops. |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
Clivefog
Lenb,
Nicedayforit
Ok |
The only way to systematically find a battery drain is to connect an ammeter in series with the battery positive terminal and then pull fuses one at a time until the drain drops to almost zero. When you find the fuse where the drain is you have found the circuit causing the issue. That will give you an idea of where to look next |
I did have an old Nokia phone in there, afraid I was lazy and just 'snipped' the wiring |
Regarding the phone.
I will give that a look, although I've looked for water ingress and can't find any (the TV has stopped working though). Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Re the TV, the screen is blank or noisy? My TV doesn't work but that's because it's analogue and TV here is now digital. Ron B. VK2OTC
The TV caused the display to go blank 12 months ago. I bypassed the TV and got the screen back. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Since removing fuse 12 (HEVAC control panel) I've regularly checked battery voltage and made notes:
You could certainly switch the mini fan and for that matter the heater/ac fan by simply replicating removing Fuse 12.
