Home > Maintenance & Mods (L322) > Bonnet Release Cable |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Ahhhhhhhhhhhhh
23rd May 2016 4:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
http://www.fullfatrr.com/forum/topic37041....nnet+cable
23rd May 2016 4:46pm |
What would I do without my Stan
23rd May 2016 4:49pm |
Just did a Google search for FPF500010 and its the same.
23rd May 2016 4:51pm |
23rd May 2016 5:02pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Happened to me too, a while back. Rather annoying, isn't it? |
23rd May 2016 6:52pm |
Annoying ummmmm too right. Range Rover quotes.....
23rd May 2016 7:07pm |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
Just spotted this in the for sales, after reading your thread:
24th May 2016 6:53am |
Spotted that as well but already ordered a new one.
24th May 2016 2:02pm |
Ok, just had 5 minutes and had a look at the bonnet cable. When I pull the handle I feel resistance like it's connected to something but the bonnet will not open.
28th May 2016 7:51pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
The cable is in two pieces, there is a joint half way down the drivers inner wing... Pete
28th May 2016 8:13pm |
So I presume I have to remove the inner wing cover to access this join. Range Rover quotes.....
28th May 2016 8:46pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
No sir, its accessible from under the bonnet |
28th May 2016 9:04pm |
So how am I going to access it if I can't open the bonnet? Range Rover quotes.....
28th May 2016 9:34pm |
It usually breaks inside the car, the resistance you can feel could be the return spring... take it apart inside and see if you can find the end of the cable, get some pliers and give it a good tug....... Pete
28th May 2016 10:14pm |
