![]() | Home > Maintenance & Mods (L322) > Bonnet Release Cable |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
And if it breaks at the other end and not in the car how am I going to get the bonnet open then? Range Rover quotes.....
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6415 ![]() ![]() |
I believe the only way is to remove the wheel and inner wing on the passenger side (Left Front), "get in there" (or find suitable small person who can), which gives access to the catches, and with tools release the catches.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^ That's what happened to mine. My first question to the mechanic was, "how did you get the bonnet open?" He explained that the cable broke inside the car, so he just put some vice grips on it and pulled. Bonnet opened. |
Round two...... Ding, ding.
Well thanks guys you lot was smack on the button.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
TDSIX Member Since: 18 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
Thread resurrection.. but I'm having a similar issue.. when I pull the bonnet lever in the car, only the driver side pops up. The passenger side of the bonnet is still locked. How do I open it? 2010 FF 4.4 TDV8 Vogue - Gone
Solved.. https://www.fullfatrr.com/forum/topic54762.html 2010 FF 4.4 TDV8 Vogue - Gone 2007 FF VSE 3.6 TDV8 - Gone 2011 RRS HSE 3.0 TDV6- Gone 2003 FF TD6 Vogue - Gone 2006 FF TD6 - Gone 2007 FF 3.6 VSE - For sale 2011 FF 4.4 TDV8 - Current |
