![]() | Home > Technical (L322) > PCV valve l322 |
fullfatbob Member Since: 29 Apr 2016 Location: sussex Posts: 15 ![]() ![]() ![]() |
Wanted to share some of the bits and bobs from my experience changing the PCV valve on the back of the 4.4 V8!
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Excellent write up! |
So was mine! Actualiteit stamped 2001! So never changed either, despite the engine was running fine, but leaking oil.
Yes the valley pan...I have also watched the video's, it is the lpg rails etc that add to the problem..especially if the wires are brittle with the heat!
Haha we have exactly the same car! Need to do the pixel repair as Well.. Cheap fix for only 18 pounds. But I believe it was a hell of a jobs which required a lot of patience... But Well worth the effort of corurse.
Hi Pietertje,
