Home > Technical (L322) > PCV valve l322 |
fullfatbob Member Since: 29 Apr 2016 Location: sussex Posts: 15 |
Wanted to share some of the bits and bobs from my experience changing the PCV valve on the back of the 4.4 V8!
18th May 2016 9:42am |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Excellent write up!
18th May 2016 2:07pm |
So was mine! Actualiteit stamped 2001! So never changed either, despite the engine was running fine, but leaking oil.
19th May 2016 10:18am |
Yes the valley pan...I have also watched the video's, it is the lpg rails etc that add to the problem..especially if the wires are brittle with the heat!
19th May 2016 3:10pm |
Haha we have exactly the same car! Need to do the pixel repair as Well.. Cheap fix for only 18 pounds. But I believe it was a hell of a jobs which required a lot of patience... But Well worth the effort of corurse.
19th May 2016 3:34pm |
Hi Pietertje,
20th May 2016 9:59am |
