![]() | Home > Technical (L322) > Rear parking sensors |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes, if one of the 8 sensors fail none will work sir... F or R |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 ![]() ![]() ![]() |
Hi Everybody.
There are several threads covering reverse sensors if you use the search function above sir...
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
A new rear loom from a main dealers is about £40 it's worth taking the front bumper off as well to check the connections I found a cowboy had been in my front bumper and i had to do some repair work L322 2008 vogue
Thank you of those. But, would a broken loom allow the sensors to work occasionally as they do now?
it sound like an intermittent fault which could be a harness plug or wire easiest way it to bite the bullet and pull the bumpers off it's not a long or complicated job just a series of bolts if you get stuck
Thank you for the video. I presume that one loose wire or plug or anything would effect both front and back sensors then? So, hopefully, if I find a prob after taking off the first bumper, that will fix the other end as well. |
yep one wire will do it my money would be on the rear sensors £40 for a new harness from a main dealers if it's the front ones then you're going to have fun.
If you have a tow bar? Plug the electrics in and it will bypass the rear system! Therefore, if the fronts work (with a light board connected) your problem is with the rear end sir |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 ![]() ![]() ![]() |
Update on my sensors, plugged in the new sensor to the rear, still the same, select reverse, long beep & light flashes 6 times but not working.
Update on my sensors, decided to order a new rear wiring loom, local Indy was £50 + vat, 5 days delivery, so phoned local RR dealer in Belfast, £25 all in with next day delivery! Great service.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
you can just hear it with engine running ,
if you're having trouble hearing it try using a funnel and a bit of hose stating the obvious but put the mouth of the funnel over the sensor then listen through the hose L322 2008 vogue
Good idea! Current: 2015 4.4 SDV8 Autobiography
