Home > Technical (L322) > Rear parking sensors |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Yes, if one of the 8 sensors fail none will work sir... F or R |
15th May 2016 10:42pm |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 |
Hi Everybody.
16th May 2016 5:06am |
There are several threads covering reverse sensors if you use the search function above sir...
16th May 2016 7:47am |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
A new rear loom from a main dealers is about £40 it's worth taking the front bumper off as well to check the connections I found a cowboy had been in my front bumper and i had to do some repair work L322 2008 vogue
16th May 2016 8:13am |
Thank you of those. But, would a broken loom allow the sensors to work occasionally as they do now?
17th May 2016 6:00am |
it sound like an intermittent fault which could be a harness plug or wire easiest way it to bite the bullet and pull the bumpers off it's not a long or complicated job just a series of bolts if you get stuck
17th May 2016 8:19am |
Thank you for the video. I presume that one loose wire or plug or anything would effect both front and back sensors then? So, hopefully, if I find a prob after taking off the first bumper, that will fix the other end as well.
19th May 2016 4:54am |
yep one wire will do it my money would be on the rear sensors £40 for a new harness from a main dealers if it's the front ones then you're going to have fun.
19th May 2016 7:37am |
If you have a tow bar? Plug the electrics in and it will bypass the rear system! Therefore, if the fronts work (with a light board connected) your problem is with the rear end sir If the system does not work??? (with the light board still plugged in) I would make the assumption the front is the source of your problems |
19th May 2016 8:09am |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 |
Update on my sensors, plugged in the new sensor to the rear, still the same, select reverse, long beep & light flashes 6 times but not working.
26th May 2016 4:10pm |
Update on my sensors, decided to order a new rear wiring loom, local Indy was £50 + vat, 5 days delivery, so phoned local RR dealer in Belfast, £25 all in with next day delivery! Great service.
30th May 2016 2:29pm |
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 |
you can just hear it with engine running ,
30th May 2016 3:46pm |
if you're having trouble hearing it try using a funnel and a bit of hose stating the obvious but put the mouth of the funnel over the sensor then listen through the hose L322 2008 vogue
30th May 2016 9:28pm |
Good idea! Current: 2015 4.4 SDV8 Autobiography
31st May 2016 8:39pm |
