![]() | Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I just had a closer look. The tank has a couple of marks and words "cold fill range". The tank looks like honey comb. It has coolant sitting at the bottom of the lower mark. ______________________________
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
I would keep topping up until the level is good (I would aim for at least half way between the min and max cold full lines). Then drive it and keep an eye on the coolant - if the level keeps dropping you probably have a leak of some sort. It may be the level was just so low that you adding a small amout didn't really change things. |
Thanks. I added 1 lt to top it up. It was above the top mark when cold. Then drove it for 4 hrs and it dropped back. ______________________________
Could have been air in the system from being low in the first place. I would fill again and keep an eye on it.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
That's what was happening to me with the thermostat housing leak, it was losing a similar amount of coolant but could not see it running down the back of the block till it was quite bad. It must have mostly evaporated, could smell it though.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Hey rar110
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 ![]() ![]() ![]() |
I had the same the O ring that goes into the block leak's (common fault) , While your there do the water pump chance's are it's bleeding past that O ring as well ...Both genuine item's are not expensive .. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
If you can't find the leak, have it tested to ensure it's not the head gasket - that is expensive to fix. |
I can just make out water and red residue around the bottom of the oil filter.
Yes, the leak runs from the housing along the valley and down the back of the block. When it's leaking slow the coolant evaporates before it can leave a puddle on the ground, but you can smell it, poke around the thermostat housing with an inspection, it's very difficult to isolate.
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
That would leave tell tale red stains as well?
Gday gents, I'm not sure I have a leak.
Definately leaking. |
Ps, I wouldn't be driving it, looks like the tank is empty and there's no indicator to say how much coolant is down in the engine.
