![]() | Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
makes sense
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 ![]() ![]() ![]() |
Egr valve
End of cooler
Pete I'd be looking in these two spots with an inspection camera to try isolate a coolant leak.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Thanks Paul, much appreciated.
If you take the engine cover off, and whilst kneeling on a bar stool, lean over the engine and look down the area around the oil filter, you may see the red crust of evaporated coolant.
Thanks. I looked in those three places as best I could with the torch. No sight of any coolant residue. I'll look again when I get a camera probe. ______________________________
The camera arrived today. I had a good look around both sides of the driver side intercooler hose at the manifold end, and behind the oil filter housing, and both EGRs (the inner side). I found nothing except a bit of oil residue between the oil filter and oil cooler (I think it's the oil cooler).
But is losing coolant on a drive?
Thanks Paul. Yes level drops back on a longer drive. Around the block no change.
Maybe try fast idling to see if coolant goes down.
I will give it a go. ______________________________
I was thinking of a way to see if egr cooler(s) potentially leaking.
