Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level
Page 1 of 4 1234>
rar110
The coolant tank has a marker indicating when coolant should be added. It was below that level but still had coolant at the bottom. So I added 1 lt of premix and by next stop its back to the same level. Is that a problem? I haven't noticed a leak. ______________________________
Post #380015 29th Mar 2016 11:49pm
rar110
I just had a closer look. The tank has a couple of marks and words "cold fill range". The tank looks like honey comb. It has coolant sitting at the bottom of the lower mark. ______________________________
Post #380017 29th Mar 2016 11:59pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I would keep topping up until the level is good (I would aim for at least half way between the min and max cold full lines). Then drive it and keep an eye on the coolant - if the level keeps dropping you probably have a leak of some sort. It may be the level was just so low that you adding a small amout didn't really change things.
Post #380070 30th Mar 2016 1:08pm
rar110
Thanks. I added 1 lt to top it up. It was above the top mark when cold. Then drove it for 4 hrs and it dropped back. ______________________________
Post #380128 30th Mar 2016 10:25pm
kezbo1981
Could have been air in the system from being low in the first place. I would fill again and keep an eye on it.
Can you smell coolant when the engine is hot?
Post #380142 31st Mar 2016 8:48am
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
That's what was happening to me with the thermostat housing leak, it was losing a similar amount of coolant but could not see it running down the back of the block till it was quite bad. It must have mostly evaporated, could smell it though.
Paul
Post #380176 31st Mar 2016 2:26pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Hey rar110
Did you find a leak?
I seem to be having the same issue.
Post #385151 4th May 2016 5:46am
STU TDV8
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I had the same the O ring that goes into the block leak's (common fault) , While your there do the water pump chance's are it's bleeding past that O ring as well ...Both genuine item's are not expensive ..
Post #385152 4th May 2016 7:07am
If you can't find the leak, have it tested to ensure it's not the head gasket - that is expensive to fix.
Post #385153 4th May 2016 7:09am
cheezels
I can just make out water and red residue around the bottom of the oil filter.
Is that the symptoms of thermostat housing leak?
Post #385157 4th May 2016 8:04am
Hammer
Yes, the leak runs from the housing along the valley and down the back of the block. When it's leaking slow the coolant evaporates before it can leave a puddle on the ground, but you can smell it, poke around the thermostat housing with an inspection, it's very difficult to isolate.
Paul
Post #385197 4th May 2016 1:43pm
Road Stone
Australia 2007 Range Rover Vogue SE TDV8 Java Black
That would leave tell tale red stains as well?
That's what I look out for, but the loss of 1ltr is quite a bit.
Cheers, Jerry THIS WRECKAGE
Post #385206 4th May 2016 2:43pm
rar110
Gday gents, I'm not sure I have a leak.
The reservoir has coolant at the front and bottom of the tank. I can't understand how the tank works. There's lots of compartments in there. Here's a pic from a month ago.
My thermostat housing was replaced about 3 years ago. I hope the replaced the grommet. ______________________________
Post #385345 5th May 2016 12:26pm
Hammer
Definately leaking.
Post #385475 5th May 2016 11:47pm
Hammer
Ps, I wouldn't be driving it, looks like the tank is empty and there's no indicator to say how much coolant is down in the engine.
Can you see red coolant residue around the bottom of the oil filter?
Post #385477 5th May 2016 11:53pm
Page 1 of 4 1234>
