![]() | Home > Maintenance & Mods (L322) > TD6 - to blank off EGR or remove and clean? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Get rid |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
Is there a link to another post to show how to remove or clean? Would like to give it a go but or at least see if its something i could turn my had too. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
FYI if you haven't already downloaded "2002-2006 workshop 'REPAIR' manual RAVE" in wiki, DO IT! it will tell you everything you need to know about taking bits off of ffrr's....... if your lucky you can sometimes find the instructions to reassemble |
cheers miggit, going to have a look at the guide, will use the search option to track it down
Yeah....well......i knew that. |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88 ![]() ![]() ![]() |
To convince yourself that it will be worthwhile do a comparison test.
N11roadwarrior Member Since: 12 Jun 2016 Location: Wicklow Posts: 2 ![]() ![]() |
Hello all, which EGR blanking kit would you recommend ? |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 759 ![]() ![]() ![]() |
Thought I'd resurrect this old post guys, after a house move and other time consuming things I've now got more time to spend on the old girl (the FF, not the missus |
Hi all
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Egr removed on my td6 by somebody ( |
Miggit, Ive downloaded your link and unzipped it ![]() |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 ![]() ![]() ![]() |
been disconnected on mine for 9 years and about 60000 miles, no ill effects, just pulled off the pipe and blocked it, maybe should have done more but i diddnt and its ok to date (touch wood) 2011 4.4 tdv8 autobiography black
