Home > Maintenance & Mods (L322) > How to bleed new fuel filter |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
You shouldn't need to bleed the fuel filter. May require a few extra cranks initially but should fire up after that. This assumes all is well on the fuel delivery system further back down the line! .
17th Jan 2015 4:29pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3964 |
As above, just crank the engine 3 times with out letting it start so as to fill the filter, then go for it.
17th Jan 2015 5:10pm |
Rob Member Since: 17 Jan 2015 Location: south Posts: 6 |
Thanks for that I really appreciate it |
17th Jan 2015 5:31pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
is this the same for a tdv8, no bleed required ? |
25th Apr 2015 5:40pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Just stick the ignition on for 20 secs at a time 2 or 3 times to help the pumps refill the system then crank till it starts Leave it to run for 10 mins so it clears any more air from the system... |
25th Apr 2015 6:45pm |
thankyou |
25th Apr 2015 7:03pm |
25th Apr 2015 8:59pm |
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 |
What does the dead end pipe do then? Got enemies? Good, you have stood up for something in your life. Never regret growing old, it is a privilege denied to many. |
2nd Apr 2016 11:31am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
AKAIK its a turbo breather.
3rd Apr 2016 6:43am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6707 |
If it still won't start, pull off the plastic engine cover and look for a pipe that has what looks like a tyre valve, remove the cap and push it down as you crank the engine.
3rd Apr 2016 9:53am |
